Old 06-25-2009, 02:58 PM   #1
Trader Rating: 56 (100%+)
Default TC4 setup tips
I just finally ot my tc4 running correctly and now that it is up to speed I can say two things. For one, I can go up a few teeth on my pinion. Two, it doesnt handle worth dump right now. We do mainly parking lot racing and I was recomended rubber tires. I have them on and the car has a tendency to get really loose. I only did a few passes to make sure everything was running right but I know as a fact I wouldnt make it around a track the way it is now. Any tips or pointing fingers towards other threads with good tips would be awesome. Thanks guys and happy racing.
Ride1226 is offline   Reply With Quote
Old 06-25-2009, 04:02 PM   #2
There is a thread just for TC4. Just search for it in the on road electric forum.
Also, it sounds like you need big time set up help. I just got back into R/C and started racing w/ a used TC4 in a VTA class. Before you start changing things haphazardly it would do you well to learn about setup. Trust me, I was there. Theres a book by XXX Main called "Touring car chassis set up guide" 18 to 20 bucks. There is also a great free DL from the Xray website that I was directed to. You'd have to google that one but it's worth it.
After that, don't forget about the racers at your track. They are very helpful to newbies most of the time. They also know that track.
When you start posting more questions try to be very detailed about your setup and the track your running. Folks here need that info to be more helpful to you. They have helped me alot.
Have fun.
Tiger72 is offline   Reply With Quote
Old 06-25-2009, 06:07 PM   #3
Have fun.
Gotcha buddy and I understand that the more info the better. Funny how I can set up and fly the heck out of a heli but this on road thing is a whole new beast to me. Ill do a search for some tc4 setup tips a bit more and see where that leads me too. I really have zero clue to begin but this is my learning car until I outfit my JRXS type-r LOSI.
Old 06-26-2009, 03:31 AM   #4
Foxxrocket's Avatar
I also run asphalt. Here are a few things you can change that might improve your cars handling. -2 of camber all around, 1 toe-out in front and 2 toe-in in rear, 4 droop all around, 4.3mm spacing on front springs, 4mm spacing on the rear, and 6 of front caster.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Team Associated TC4 Kenshin Electric On-Road 15368 Yesterday 09:23 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Vintage Trans Am Class Drifter73 Nebraska/Iowa Racing 1225 12-18-2014 01:55 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
Xray T2R, 2100 mah 2c LiPo, and Mabuchi power: Tech tips and Tricks gacjr0 Electric On-Road 46 11-18-2007 10:09 AM
