Corally RDX Droop
What are you guys using or have used on the RDX for Droop settings? Asphalt and Carpet Rubber tires?
Originally Posted by jhock
(Post 5976739)
I know, just lookin for everyones settings on there RDX
ah I just usually eyeball it, but usually more in the front. If i can remeber, I think maybe like 4 mm or something close to that in the front.
Using an Associated droop gauge, I usually start with 5mm front and rear for carpet and asphalt.
For VTA and RCGT, I have 6mm ride height with 3mm droop above ride height front and rear, for both asphault and carpet.
I then make 1/16 of a turn adjustments at the track depending on traction and performance. I always stay within 2-4mm of droop front and rear. |
