Joe B |
01-05-2004 01:32 PM |
Im not sure if you were aware....but,It's not a direct fit for the factory chassis.....you can drill and countersink holes of your own as well as milling (dremeling) some of the webbing out in that area...but in my honest opinion it's not worth the effort on the factory chassis........this is (one) of the benifits of going to a carbon fiber chassis Such as BMI where it gives you this option as a direct fit.......the nitro rack has a little less slop and is more trouble free in it's design ......but...at the expence of an akerman change that causes a (slightly) less aggresive feel that you may or may not like........personally I diddn't so I switched back to the factory one...... I just keep it clean between runs to avoid any problems.....hope this helps some
