Old 06-22-2009, 06:30 PM   #1
capturefx's Avatar
Default HELP! JUST BOUGHT A DURATRAX ICE CHARGER DINT REALIZE NO BALANCER
Hi everyone, i just bought a duratrax ice charger and realized after the fact that is not capable of balancing a lipo battery???? does anyone know a good model external balancer unit that will work with the ice charger.. i feel like a dummy right now for not checking if its got a built in balancer, i herd that its such a good charger so i just kinda bought it.
please any info will be greatly appreciated
capturefx is offline   Reply With Quote
Old 06-22-2009, 06:32 PM   #2
LOW ET's Avatar
Trader Rating: 97 (100%+)
astroflight blinky
LOW ET is offline   Reply With Quote
Old 06-22-2009, 06:39 PM   #3
capturefx's Avatar
im new to the rc electric scene coming from the nitro rc, does lipo batteries need to be balanced all the time per charge ??? how often do they have to be balanced? and how can everyone say that the ice is a good charger without the balancer. so is it ok to charge lipo batteries without balancing them??
Old 06-22-2009, 06:40 PM   #4
LOW ET's Avatar
yes you can charge without balancing and no you dont have to balance every charge. balancing is over rated.
Old 06-22-2009, 06:47 PM   #5
Trader Rating: 16 (94%+)
Good thing is that you probably don't really need a balancer with a 1, 2, or 3 cell LiPo Battery. The batteries just don't get out of balance that easy, that is unless one has a bad connection or is going bad.
You can borrow or use someone else's balancer about every 2-3 months, and watch the numbers as it charges/discharges, and you will see that the cells are almost always within .02 volts of each other.
Over the years, I've put my LiPo's on balancers and have not yet ever found any of mine to be out of balance by more than .02 volts. My experiences are with SMC, Orion, and MaxAmps LiPo's.
Just 1-month ago, a local racer brought his 3-year old Orion 4800mAh 15C battery to me to balance, as he had never done it. To my surprise, this 3-year old pack was .01 volt out of balance. IMO, this does not even warrant the need for a balancer.
Save your money and enjoy running your LiPo battery.
kn7671 is offline   Reply With Quote
Old 06-22-2009, 07:29 PM   #6
myrxseven's Avatar
I only balance low quality cells, as they are more apt to become very unbalanced after a while.
myrxseven is offline   Reply With Quote
Old 06-22-2009, 07:38 PM   #7
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
equinox
R
UltegraSTI is offline   Reply With Quote
Old 06-22-2009, 08:27 PM   #8
V_28's Avatar
when your at the track next time just ask someone to do it for you. as stated above, you only need to do it every 2-3 months and even then i find that the cells are barely off from one another if at all.
V_28 is offline   Reply With Quote
Old 06-23-2009, 10:44 AM   #9
capturefx's Avatar
THANKS EVERYONE FOR ALL YOUR HELP! i was over here having a panic attack cuz i spent $100+ dollars on a duratrax ice charger realizing that it doent have a built in balancer . anyway thanks for all the info its greatly appreciated.
