Old 06-22-2009, 05:27 PM   #1
CCH1978's Avatar
Trader Rating: 27 (100%+)
Default motor temps
Hi guys, what is the hottest a brushed motor should get?
MINI REVO Mamba Max Pro NEU POWERED
THE BEATINGS WILL CONTINUE UNTIL THE MORALE IMPROVES
BEAST MODE (ON) OFF
CCH1978 is offline   Reply With Quote
Old 06-23-2009, 06:59 AM   #2
Trader Rating: 26 (100%+)
For most brushed motors out there 140-145 degrees is the limit and not the 160 degrees of brushless. Some of the super fast mods (under 10t) will want to be kept cooler. A lot of how hot you want the motor is determined by the tracks you run. If you run off road or on-road road course track you will want to try and keep it under 130. If you are bashing or running pan car you can push the 140 limit. Just remember that the more times you push the temp the faster the brushes are going to wear out.
racerj3 is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13771 Today 06:13 AM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
16th erevo/slash May14th baileysmicro Micro and Mini Scales 2199 07-16-2013 09:42 PM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 04:19 PM
Lipo Heat during a race nwilcox88 Electric Off-Road 21 08-15-2009 11:23 AM
SC10 Brushed motor need help! dsl Electric Off-Road 12 08-11-2009 10:19 AM
IRS Chassis for TC3 Bosscat Electric On-Road 25 03-17-2002 08:00 PM
