Old 06-21-2009, 08:10 PM   #1
Default AMB Transponder Mounting
Just gotten an amb transponder. In the manual it says to mount it vertically.... If i do it horizontially will it will be picked up?
~AR~ Gizmo is offline   Reply With Quote
Old 06-21-2009, 08:15 PM   #2
Rod M's Avatar
it should work either way but I always believed horizontal was better?
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 06-21-2009, 08:18 PM   #3
Trader Rating: 38 (100%+)
I've seen them mounted vertically in a lot of cars but everytime I've tried I would start missing laps.
or8ital is offline   Reply With Quote
Old 06-21-2009, 08:30 PM   #4
Regional Moderator
CarbonJoe's Avatar
Look at almost every 1/8 scale off road vehicle... they mount the transponder horizontally. The CRC Gen-X has the slot at the front of the car for a horizontal mount. Since I move my transponder between my on-road and off-road cars, I don't want to cut off the 3 mounting tabs, so horizontal it is.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 06-21-2009, 09:10 PM   #5
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
horizontal... as low and as far forward as you can mount it, simple.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-04-2009, 12:57 AM   #6
bigfix's Avatar
Exclamation AMBrc DP Transponder mounting
Hello Gizmo
I will assume you are refering to an AMBrc DP (Direct Powered) transponder.
Also commonly known as PT or personal transponder.
For best performance the AMBrc DP transponder should be mounted label side up (flat). Avoid mounting vertically!
To get the edge on your competition mount it as far forward in your car as possible.
However, in serious competitions the position maybe regulated.
Here is a direct quote from AMB documentation...
"The transponder must be mounted horizontally (flat).
The position of the transponder must be identical in all RC model cars competing in the race for best finish accuracy.
Transponders must be positioned no higher than 15 cm / 6 (lower is better), with no metal or carbon fiber between the transponder and detection loop."
AMBrc (handout rechargeable) transponders should be mounted with the post vertical and the side with AMB embossed on it should be facing down to the race way. It is OK to have the post tilted up to 45 degrees, as it is common to mount it through the windsheild of the Radio Controlled car.
This document and many other AMB transponder system documents can be found at my website www.transponderservices.com
best regards
Jeff
Transponder Services
bigfix is offline   Reply With Quote
Old 07-04-2009, 11:05 PM   #7
Trader Rating: 29 (100%+)
Mount to your front bumper. I've never had any problems.
RSTECH is offline   Reply With Quote
Old 07-05-2009, 08:43 AM   #8
Trader Rating: 36 (100%+)
I used to mount my transponder vertically on this side of the servo and it worked fine but, recently at a new track, it began missing laps. I then changed it to horizontally and have not had any problems since.
EVILGRAFX is offline   Reply With Quote
AMB Transponder Cloning Terry_S Electric On-Road 449 05-20-2013 12:11 PM
Indoor Carpet Racing @ RC Performance in Madison Associated-08 Wisconsin & Illinois Racing 3426 11-25-2010 04:03 PM
TRUCK RACING (ASPHALT OFF ROAD) AT RC HOBBIES RACEWAY mrrcguy Arkansas / Mississippi RC Scene 79 08-08-2009 01:03 PM
Stealth PT - New PTX Personal Transponder Terry_S Electric On-Road 591 06-26-2009 06:27 AM
amb transponder mounting info? 8ightisenough Nitro Off-Road 7 11-28-2008 05:49 PM
AMB Personal Transponder FS crashnburn R/C Items: For Sale/Trade 9 06-27-2005 05:19 PM
