Old 06-21-2009, 07:04 PM   #1
Trader Rating: 20 (100%+)
Default Brushless Motor Temps
Hey guys,
Just chasing some input on what temps you guys are getting off your Brushless motors. In particular 17.5 Brushless for both Novak and LRP motors. I know it varies from different manufacturers, but what is acceptable? I'm trying to gear my TC to motor temps and so far I've had to run ridiculous FDR's (3.2) to be competitive at my track and my motor is coming off at around 70-80 C (158-176 F). At wat temps should I be concerned?
Cheers
bee200sx is offline   Reply With Quote
Old 06-21-2009, 08:45 PM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally Posted by bee200sx View Post
Hey guys,
Cheers
keep it around 165 and you should be just fine anything over that i would be concerned
Old 06-22-2009, 12:50 AM   #3
Super Moderator
Grizzbob's Avatar
Right, & while it may not be exactly meant for ALL brands of brushless motors, I think Novak's notice on that(found here: http://www.teamnovak.com/tech_info/i..._motor_doc.pdf ) can be a good guideline....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-22-2009, 01:58 AM   #4
aussierevo's Avatar
Trader Rating: 14 (100%+)
I need to ask the silly question....sorry in advance... when using your temp gun to measure the temp's of the motor, what is the best place to take a reading from.....end of motor, or just point it at general direction of motor.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 06-22-2009, 02:34 AM   #5
Skitee's Avatar
If the motor has a metal end cap then you can temp it, otherwise temp the center of the can or through a vent if your motor has vents. If the motor can is silver then you need to temp it where the decal is to get a good reading.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 06-22-2009, 10:33 AM   #6
I stay around the 70 C with a max of 75 C. I use this temp with all of my motors.
GM says that the best temp is about 80 C. I don't think that's a good for most motors. The most motors can't handle to high temps and they forget that you measure the outside temp and that the inside temp is even hotter.
I have seen and heard that many motors are burnt because of to high temps.
So keep the motor cool.
Use a motor cooler as you are getting close to the 80 C.
Better a bit slower over the race than a burnt motor no finish and no motor after the race.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 06-22-2009, 01:09 PM   #7
razzor's Avatar
On stock speedpassion motors i was told to temp the center of the bearings to measure the rotor temp and reference against the can temp.
Can temp of around 65 - 75 deg/c max.
When you gear longer there will be a bigger difference in temp between can and rotor. From what i have experienced rthe otor is anything from 5 to 10 deg hotter.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-22-2009, 03:43 PM   #8
Skiddins's Avatar
Seems to vary with each manufacturer.
I take the gun and test all over the motor until I find the area that's hottest.
On Speed Passions etc where the endbell bearing is exposed you can see the end of the rotor in the centre of the bearing.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-22-2009, 04:14 PM   #9
aussierevo's Avatar
thanks for this information guy's....very handy. I've been running mine around 60 degrees, so that is ok for me.
Speed Passion F1.
RC BOAT jann Manila Racers 5327 09-19-2017 12:44 AM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Hot Bodies Cyclone D4 EP buggy Mike Schumacher Electric Off-Road 1921 10-06-2014 12:33 PM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 01:35 PM
General Setup info skypilot Northwest Racers 59 12-10-2012 06:02 PM
Best 17.5 brushless motor for off road? dennyboy424 Electric Off-Road 44 01-15-2009 09:02 PM
1/8th scale buggy brushless motor/esc recommendations? dirtracer1 Electric Off-Road 30 10-02-2006 07:41 PM
