Old 06-20-2009, 11:39 PM   #1
Soundstream's Avatar
Send a message via Skype™ to Soundstream
Default tamiya trf 416 we or kyosho tf-5 stallion
Wanted something a little different, just cant decide between the two. any experiences would be appriciated!
Soundstream is offline   Reply With Quote
Old 06-21-2009, 10:11 AM   #2
94eg!'s Avatar
Trader Rating: 17 (100%+)
Compared to the Stallion, the 416-WE is cheaper for what you get.
Stallion has plastic upper bulk-heads, plastic center shaft hold-downs, a very wide lower deck, steel turnbuckles, and is also a couple years older. Also the stock steering tie-rod turnbuckles interfere with the suspension mount at full lock and must be replaced with something lower profile...
Stock setup for the 416 is front spool.
Stock setup for the Stallion is front one-way.
This may also be a factor that helps you pick...
94eg! is offline   Reply With Quote
Old 06-21-2009, 10:57 AM   #3
i love my 416 world edition
the best car i have driven , although i must admit i like the Xray 009 almost as much
not driven or seen the Kyosho so i can't comment on that car
be quick with your decision as the TRF416WE is short stock as far as i read
sidecarphil1 is offline   Reply With Quote
Old 06-21-2009, 12:07 PM   #4
94eg!'s Avatar
BTW:
The Kyosho Stallion "Shin" edition seems to be a MUCH better car all around vs the regular TF5 Stallion. I'm guessing it's gonna cost more though. No more plastic bulk-heads or diff out-drives. It appears to be fully hopped up. I'm guessing the steering turnbuckles will still hit the suspension blocks though, and need replacing...
Here's a nice review and comparison: http://www.overrc.com/techniques/reg...allion_eng.htm
