Novak brushless ? >
Novak brushless ?
Novak brushless ?
Old 01-03-2004, 09:27 AM
OutlawPro3's Avatar
Default Novak brushless ?
Has anyone used the Novak SS system in an HPI Pro3?
any recommendations for spur and pinion gearing and setups?
Thanks.
OutlawPro3 is offline
Old 01-04-2004, 08:29 AM
OutlawPro3's Avatar
Anyone
Old 01-04-2004, 10:03 AM
lee82gx's Avatar
i have used both but never together.i guess it's as close as u can get around here.
For gearing,if u're using rubber tyres on asphalt:
try 6.8-7.0.no need to change the gearing if u're switching between profiles.
Setups:
I'd say pink front and blue springs rear.30wt oils.I hope u have the rest of the setups bcos that's all i can remember.
I suggest getting a Hotbodies upperdeck or HPI upperdeck for better response.
As for the BL,dont worry if u get thermal shutdowns.try using a fan(5V) on the ESC.
lee82gx is offline
Old 01-04-2004, 10:49 AM
OutlawPro3's Avatar
Thanks Lee,
I was going to start with a 27 tooth pinion and a 84 tooth spur - 6.99 final ratio.
I've got the Hot Bodies upper deck as well as the HPI graphite main chassis, any idea where to get a fan for the speed control?
Old 01-04-2004, 05:40 PM
lee82gx's Avatar
a fan.i believe Reedy is selling them.u can check out latest photo's of Barry Baker's TC3.he has one on it.
lee82gx is offline
Old 01-04-2004, 05:42 PM
OutlawPro3's Avatar
Allright, cool.
Old 01-04-2004, 08:07 PM
pro3racer's Avatar
my friend wants to get a BL, and he wants to know what the novak motor is equivelant to a brush motor. He was thinking a 12 turn, i thought that was alittle too fast.
pro3racer is offline
Old 01-04-2004, 08:29 PM
Kennedy's Avatar
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
If you look 3 or 4 pages back there is a thread "Novak Super Sport Brushless system" and it should answer most of ur queries.
What's good about the the Novak Brushless is the is it has 6 selectable throttle programs. I suggest spending the bucks(not that much nowadys anyway) and spend teh first 3 monthe on the Sportsman profile which limitys its to something similar to a stock 27turn but still has the blistering punch of the unlimited profile whicj is probably the hardest thing to get used to. In Unlimited form the Novak is comparable to a good 12 or 13 turn.
Brushless is the future!!!!!! Better recognise
Kennedy is offline
Old 01-04-2004, 08:46 PM
lee82gx's Avatar
the punch/torque is crazy fast.
i would compare it to a 12-14T machine mod.
it's not exactly as fast in top end as those pro 12T's that are used in competitions...
but as i said,the torque is so crazy it makes up for a lot of lost ground.
lee82gx is offline
Old 01-04-2004, 08:51 PM
Kennedy's Avatar
.....and @ quite alot of tracks the top end is not an issue coz your already @ the end of a short straight before they catch up to you.
Brushed Motor Maintanence?? I could not be bothered
Kennedy is offline
