Old 06-17-2009, 01:58 PM   #1
xevias's Avatar
Default Motor temp and Temperature guns
With the reflectivity of all the motor cans, how are you guys getting accurate temperature readings?
The temp guns that work well for nitro motors are giving me much higher readings than they should because their emissivity ratings can't compensate for the reflective metal.
So instead of buying a $400 temp gun, have any of you had good results from spray painting the motor can flat black?
What are other cheap, effective ways to get accurate readings?
xevias is offline   Reply With Quote
Old 06-17-2009, 02:20 PM   #2
94eg!'s Avatar
Trader Rating: 17 (100%+)
The $30-40 O'Donnel TGX-1 has adjustable emissivity setting. Hope that helps...
I have one, and it does not give you any tips on changing emissivity. It pretty much just tells you to go on the internet to find out what settings to use...
94eg! is offline   Reply With Quote
Old 06-17-2009, 02:37 PM   #3
Trader Rating: 38 (100%+)
Small piece of black tape or black permanent marker on a spot of the can.
or8ital is offline   Reply With Quote
Old 06-17-2009, 08:32 PM   #4
Tony Newland's Avatar
Trader Rating: 50 (100%+)
If your using a decent gun and not a $10 POS it shouldnt be an issue..... we tested by painting shiny head buttons years ago to see if there was any difference.... there wasnt any
If it bothers you, point it at the sticker or something..... most motors are the hotest near the endbell
Schumacher Factory Team - Core RC - Tekin - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15109 10-10-2017 05:01 PM
Temp guns - Basic questions noR Offroad Nitro Engine Forum 19 01-27-2013 08:25 PM
Temp Gun Revelation! andrewdoherty Electric On-Road 8 10-27-2008 04:07 AM
Temp guns... again D_o_S Nitro Off-Road 26 07-25-2007 01:15 PM
Engine temp range Dredd Onroad Nitro Engine Zone 38 03-29-2007 08:14 AM
TOO HOT!!!! rcracer34 Electric Off-Road 11 11-03-2006 11:45 AM
