Closed Thread
Old 06-17-2009, 07:59 PM   #121
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by skypilot View Post
with the speeds you can get out of a 13.5 and it being cheaper then mod, most people are staying with 13.5, that is why this year our club decided not to offer the 13.5 or 10.5 classes, the result, down to a C main in 17.5, Full heats of Mod and growing with record turn outs.
Best idea ever.
There are way too many classes to choose from, which is killing the turnouts out this way in all of them.
Randy Caster is offline
Old 06-17-2009, 08:17 PM   #122
Regional Moderator
CarbonJoe's Avatar
Originally Posted by MACHFIVE View Post
Stock needs to be a 13.5 and Mod unlimited.
No, stock needs to remain 17.5. I thought that the consensus was that 17.5 was plenty fast (almost too fast) for stock. Look at the lap times Josh posted above. Why would we make stock even faster with a 13.5, unless you're also considering 1s LiPo for stock?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline
Old 06-17-2009, 08:21 PM   #123
Danny-b23's Avatar
Originally Posted by syndr0me View Post
The first thing that should be solved is making mod the same around the world. 5 cell is nice, but it's based on NiMH, which is clearly on its way out.
So, at the risk of offending the open mod purists... what about a World Spec Modified class? Something that's (hopefully) adopted around the world as the new mod, keeps the door open for NiMH or LiPo, and slows things down enough so they're still within reach of today's racer. Someone mentioned 10.5 max, which seems as good as anything, 'cause it's still rather fast, and is already easily available as a spec wind.
This seems to make sense on short tracks, which is where a lot of racing is done around the world. Obviously on bigger tracks, something like open mod might make more sense.
+1!
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline
Old 06-17-2009, 08:34 PM   #124
I think 10.5 is a bit too slow for a full blown modified class. Maybe 4.5 with Lipo, or 3.5 with 5 cell, and a 1450 gram weight limit for either.
Old 06-17-2009, 08:39 PM   #125
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Stock and Mod is what got us through the 1980's, 1990's and early 2000's with no real complaints or issues.
enter: the internet.
the sharpest double-edged sword man has ever seen.
*** The Gate II - Home of Mike Wise ***
seaball is offline
Old 06-17-2009, 08:45 PM   #126
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline
Old 06-17-2009, 08:57 PM   #127
Danny-b23's Avatar
I somewhat agree. 4.5 seems a bit high. maybe 7.5 with LiPo or 6.5, 5 cell and a 1450g limit.
Danny Buck
Old 06-17-2009, 10:50 PM   #128
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Excellent!!!!
21.5 VTA
17.5 Stock
13.5 SS (Super Stock) Duh! lol
7.5-10.5 MOD
All classes 2cell 7.4v 5300mAh 40c MAX
After all, if someone starts out slowly in VTA and gets good quickly, he will already have the packs to run anything! No speedo regulations so it will work for almost any class. I don't see any need for anything faster than an SPX with an 8.5 IMHO. Lets keep it below Mach one okay guys?
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline
Old 06-17-2009, 11:08 PM   #129
Just seems kinda strange to me that a 4wd mod buggy can run a 5.5, but people are scared to go lower than 7.5 in a 4wd sedan. I can't see that being all that much fun on a large track...
At last years ROAR asphalt nats, there wasn't a ton of traction, and yet modified was able to go quite a bit faster than a 10.5 (superstock at that time) was able to go. I think my fast lap with a mod was .4 faster than I was able to go with 10.5, which would put it at about .6 faster than a 13.5 we would run today.
Isn't part of the fun of mod being able to go faster than the other classes?
Old 06-17-2009, 11:19 PM   #130
For sure there are too many motor classes per class of car!
The quality of racing and therefore numbers would be so much better if Mod and Stock were the only classes at big events. Adding 10.5 as well just waters everything down.
For example an event with say, 40 Stock, 40 10.5 and 20 Modified just doesn't have the same atmosphere (for lack of a better word) as an event with 70 Stock and 30 Modified entries. This is because when there are more cars if fewer classes you will get closer racing regardless of your skill level, from the back of the field to the front of the field. Not to mention winning means a lot more too.
All I ever hear from Stock racers is how much they like the close racing on a level playing field, so it just seems so hypocritical to have 2 stock classes!
As a Modified racer, dropping back to 10.5 feels much like stock. I just don't see how racing it prepares you much better for racing Mod than Stock does. So I can't buy into the 'stepping stone' argument for the existence of this class. I only talk about this because until we fix the Stock classes, Modified will also suffer.
The Modified class has gone through many changes these past few years, in a large part to combat the high failure rates of brushed motors and the unreliability of the early brushless systems. Now that we have got to the point where equipment failures are few and far between, what we need more than anything is some stability with the rules. Every time the rules change it is very expensive for the privateers and we just lose more and more drivers.
As for stock drivers proposing changes to the modified class under the guise of making it more accessible, it has never worked. It's how we ended up with LiPo in my area and I've yet to see any stock drivers make the step up after getting their way with the rules.
qwcl is offline
Old 06-17-2009, 11:47 PM   #131
I can remember my first ROAR national, 1999 Paved Electric at Ripon Speedway. 2 classes, stock and mod. If I remember correctly 90+ in Stock TC and 60+ in Mod TC. Making the B in stock or mod was something to be proud of back then. Racing overall was better, and funner. Mod was drive-able, way less voltage and way less motor. More guys could race it.
Unless you're on a big track open mod theses days is crazy. The Reedy is a good example of how fast spec motor racing has gotten. On the typical indoor US track open mod is insane. 45-50 mph 3 lbs. projectiles flying down the back strait. Some will say it's on the verge of unsafe. Something has to change if we're ever going to see the glory days of mod sedan.
There are a lot of really good ideas here. This is an awesome discussion!!!!!!!
schurcr is offline
Old 06-18-2009, 12:23 AM   #132
fly_wheel's Avatar
y need 2 classes of stock..? doesn't make sense...
juz make them into 1... unless some r unhappy that they will have lower chances of winning plastic medals...
simply stock 13.5 n mod... u'll have more turnout...
i race 11.5t stock... mod 4.5 if the track is big... both powered by lipo... too much rules also causes less turnout...
RC race nowadays have too many classes... TC stock, TC super stock, TC mod, 12th stock..?, 12th mod..?, m-chasis..? carpet..? alpshat..? rubber..? foam..?
luckily, in my area we only race rubber/alpshat, 11.5T or mod... simple...
There are more in racing than winning.
fly_wheel is offline
Old 06-18-2009, 01:54 AM   #133
fathead's Avatar
Maybe people are looking at it wrong, maybe instead of the cars being too fast, the tracks are too slow, it seems to me that the car technology has moved forward but the tracks haven't
In full size racing the tracks are changed to accommodate the cars over the years as they have gotten faster, not the other way around (mostly).
Slavich Design
fathead is offline
Old 06-18-2009, 02:04 AM   #134
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I know in F1, a few tracks were changed to slow it down.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline
Old 06-18-2009, 02:09 AM   #135
Korey Harbke's Avatar
Just to add to that... My buddy Troy was sitting at the end of the straight with a radar gun. The cars in the A main of 13.5 were hitting as fast as 46mph if I remember right. Thats FAASTTT!!!!
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline
Closed Thread
Tamiya TB-Evolution IV gtypecanare Electric On-Road 3600 11-03-2017 01:06 PM
Schumacher CAT SX 1/10 4WD Competition Buggy Mike Schumacher Electric Off-Road 2166 06-05-2017 07:33 AM
Windsor Indoor Hobby Centre Besercoe Australian Racing 7835 06-25-2011 02:35 AM
UK Race Talk TryHard Racing Forum 9876 12-05-2010 11:46 AM
(US) Rubber/Carpet: Are we ready for mod yet? Adam? Electric On-Road 29 04-10-2009 10:14 PM
Bring Back 1/10 Scale Pan Car Poll!! gijoe64 Electric On-Road 746 10-04-2005 11:47 AM
