Cooling
Old 02-13-2002, 08:04 PM
Default Cooling
What does everyone use to cool batteries while charging? I have access to lots of old PC fans, is there something specific I nned to look for? I know I need 12 volts, but do I need to do something to limit the amps? I have a 14 amp power supply that runs my charger.
Let me know.
CS
Smilin Joe is offline
Old 02-13-2002, 08:13 PM
Fire's Avatar
Exclamation
do the battaries get excessively hot that need a fan to cool it down? if they are then there must be something wrong with either the setting of the charger, the charger itself or battaries' problem.
Fire is offline
Old 02-13-2002, 08:20 PM
The batteries don't get real hot. I can hold them with no problem. I just remember (realize I have slept many times) many years ago racing indoor off-road, everyone had fans to cool the batteries while charging. Was that just a NiCd thing?
I guess what I am ultimately trying to figure out is how many packs I am going to need for a night of racing. If I can just peak the first pack for the main, that whould be great. If they need to cool for 2 hours, then I need 4 packs. I figured if I kept the temp down while charging, it would make them happier if I needed to recharge in between race 1 and 4.
Go easy, I am very new at this.
CS
Old 02-13-2002, 10:14 PM
Fire's Avatar
Talking
As you stated~~it's a long while ago that ppl use a fan to cool the packs when charging, so need not to worry about it now if your packs are ok after charged~
a fan is a very good tool to cool down the packs while you are discharging the pack after finished the heat~ i guess there's no definite answer about how long you should wait before recharging, i just wait till the packs finish discharging on trays and cool to normal temp. and to be safe wait 15-30 min then it's ok to recharge
Fire is offline
Old 02-13-2002, 10:45 PM
shockwave's Avatar
I still use a fan. Just keeps cold lol. also cool my motor and stuff after a race.
shockwave is offline
Old 02-14-2002, 07:57 AM
I guess I was being stupid last night, cause the fan is only going to pull as many amps as it is rated for. So that solves that problem.
CS
Old 02-14-2002, 08:08 AM
Regional Moderator
Darkseid's Avatar
You really shouldn't need to cool the batteries while charging. Most modern chargers manage to charge the batterier while keeping them cool.
Now after the race, I do put my packs and motor over a fan. Just so theres a good breeze moving over them.
Darkseid is offline
