How do you change the voltage that the 16x5v6 discharges to? >
Old 01-01-2004, 01:29 PM
Default How do you change the voltage that the 16x5v6 discharges to?
According to the manuel of my 16x5v6 it discharges to .8v/cell and Promatch reccomends discharging to .9v/cell is there any way I can change this setting on the charger? Is there a signifigant diffrence between discharging to 4.8v and discharging to 5.4v?
AE Racer is offline
Old 01-01-2004, 01:47 PM
JusBox's Avatar
I don't believe you can adjust it though i've read that if you discharge under the 7 cell parameters, it will cutoff at 5.4.
JusBox is offline
Old 01-01-2004, 01:48 PM
Cole Trickle's Avatar
I dont know about your charger setup can be altered, but personally, I wouldnt worry about if it's 0,8 or 0,9 volt. The important thing is, that the discharge is shut off, when the packs starts to drop and dont go all the way to zero.
Cole Trickle is offline
Old 01-01-2004, 02:05 PM
fatdoggy's Avatar
I've got a v5 and have been using a .8 cutoff for a few months without any problems at all.
fatdoggy is offline
Old 01-01-2004, 06:46 PM
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
I don't think you can. I've been using it for awhile also with GP3300 and no issues....
Tres is offline
Old 01-01-2004, 06:58 PM
lee82gx's Avatar
no u can't(repeat)
There is no difference between 0.8V cutoff and 0.9V cutoff...since by then the cells will be dumping already.there is not even 1 seconds difference.U can watch the voltage of the pack go down from 5.4 to 4.8 in like a blink.
lee82gx is offline
Old 01-01-2004, 07:10 PM
JusBox's Avatar
Originally posted by lee82gx
no u can't(repeat)
That's true and once you take it off the discharger, the voltage jumps right back to 7.2 or around there.
JusBox is offline
