Old 07-23-2009, 12:32 AM   #121
B4james's Avatar
So do you replace front and rear dogbones and all at 48mm ?
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 07-23-2009, 01:12 AM   #122
. The biggest improvement was the arms, the tamiya arms are not so soft as corallys. they dont flex that much.
[/QUOTE]
Are the standard arms/wishbones that bad?
Is see Corally make Xtra hard arms now.
OPT RDXΦ/'09 79080 CF6 Wishbone, Front X Hard 80 (1 pc.)
_____________________
"To finish first, first i must finish!"
www.mkrctc.org.uk
www.akularacing.co.uk
Toblerone is offline   Reply With Quote
Old 07-23-2009, 03:56 AM   #123
Stusdal's Avatar
Anybody tried the softer corally arms? One of the tracs i race at has ultra low grip so iv'e orderd the arms to see it that can gice me some more grip.
Here is my ride btw.
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 07-23-2009, 04:40 AM   #124
crabboy's Avatar
Trader Rating: 58 (98%+)
WOW, the rear drive shafts are at the big angle, have you tried to rotate the rear bearing holders and run the 36t pulleys, had it on my 08 Phi and it worked
great, have set the 09 up for a run this weekend like it to, you also need to run a 416 rear belt.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 07-23-2009, 04:55 AM   #125
Stusdal's Avatar
Yeh! I notised that, but this was how it came together form the kit. So I figured it is supposed to be this way.
Are still waiting on a shipment of tuning parts, cant remember if I orderd the 36t pulleys. But I should definetly try that.
So its, 36t pulleys, 416 rear belt and the kit front belt?
Old 07-23-2009, 05:57 AM   #126
crabboy's Avatar
OK not sure if you have done it on purpose, but you have the rear hindge pin mounts on the forward holes in the chassis, they should be one hole back, and on the forward holes for super short wheel, and as for belts its a 416 rear and standard front belt.
Rhys
Rhys Marshall.
Old 07-23-2009, 06:11 AM   #127
Stusdal's Avatar
I do believe the manual showed them mounted there, but i did move it to the back hols to remove the angle. However I put them in the forward holes again to get the car to rotate better.
Belt is now order, thanks!
Old 07-23-2009, 06:18 AM   #128
crabboy's Avatar
Manual shows them mounted in the second set of holes back from the front, anyway, will post a pic of my 36t pulley car when the camera battery charges.
Rhys
Rhys Marshall.
Old 07-23-2009, 10:28 AM   #129
Send a message via MSN to _RDX_
yes exactly!
| Corally RDX Phi'09 | Sanwa M11 | Nosram |
_RDX_ is offline   Reply With Quote
Old 07-23-2009, 06:45 PM   #130
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
I used to have a Corally Phi that I ran on carpet. Looking into getting a new TC for asphalt and wanted to hear options on the Phi 2009. Any word on when it will be available in US.
Chirag
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 07-23-2009, 07:02 PM   #131
Kenny L's Avatar
Trader Rating: 16 (100%+)
I was told they should be shipping to hobby shops in the next two weeks. There was only like 20ish on the first batch. All I can say is you'll love it. The option parts are available now.
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 07-23-2009, 09:41 PM   #132
How is the car on asphalt? We have a low/medium traction track that we generally race on.
How is gonna be stocking the car? Price?
Old 07-24-2009, 06:48 AM   #133
B4james's Avatar
Pics of my finished car with running gear installed,
Old 07-25-2009, 04:37 AM   #134
B4james's Avatar
Well I took the car out for some laps today, for a first time run it definitely shows potential.
Definitely has a lot more steering than the 08 PHI, probably a little too much steering and may have to settle the car down to my liking.
I found it to be rotating to much in the rear, I tried a few different things which definitely helped slow this down and car was feeling a lot better.
Changes tried from kit settings
1st change - camberlinks in the lower inner holes on front and rear towers (Kit is upper holes)
2nd change - 2mm of washers under the camberlink on the rear hub
3rd change - spacers underneath the wishbone mounting blocks in the rear
Next I will try removing the bulkhead screw and also going to try widening front and rear track.
Old 07-25-2009, 12:03 PM   #135
Default Bulkheads
Hi, Just wondering for those of you that still have the original Phi still -will the bulkheads on the new 09 fit the old Phi07 chassis? I have a lot of older Phi stuff and if a quick fix to get the lipo to fit better is to just buy the new bulkheads I may just do that when they become available. Thanks!
Electro-MAX RC is offline   Reply With Quote
For sale/trade thread UnderDaHill Nebraska/Iowa Racing 5234 12-08-2017 05:01 PM
St Ives RC Club B4Bandit Australian Racing 16584 12-06-2017 03:53 AM
Fastlane Raceway kansasracer Kansas/Missouri Racing 17302 11-12-2017 03:30 PM
Team Corally RDX Phi syndr0me Electric On-Road 3380 03-11-2014 11:27 AM
Corally RDX Phi 2 c1 racin Electric On-Road 52 05-08-2009 02:38 PM
