Old 07-16-2009, 01:49 AM   #76
The kit shocks work fine, I think itís mostly personnel preference and you can also use the Tamiya pistons it the kit shocks if you want to.
Patrick
XCELL is offline   Reply With Quote
Old 07-16-2009, 06:53 AM   #77
Trader Rating: 38 (100%+)
If you use the Tamiya pistons you do need to shim them to fit. They are thinner then the Corally pistons.
or8ital is offline   Reply With Quote
Old 07-16-2009, 07:32 AM   #78
Yes you do. I used two brass motor shims and they hold the piston in place.
samstheman2 is offline   Reply With Quote
Old 07-16-2009, 09:02 AM   #79
Where can you find this kit? The only place I can find it is Stormer, and they don`t even stock it yet.
asfastasu is offline   Reply With Quote
Old 07-16-2009, 09:40 AM   #80
Superior Hobbies is about the fastest Corally stock in the USA (they happen to be close to the US distributor)
I found this link overseas that claims to have the 09 in stock on google. You can probably find some like this but they want 379 euros including the VAT which is VERY expensive for us to purchase.
http://shop.buggy-land.de/epages/619...Tourenwagen%22
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 07-16-2009, 11:02 AM   #81
Sorry for my ignorance, but what is VAT?
Old 07-16-2009, 11:37 AM   #82
Default VAT
Value Added Tax - so the government gets a slice of the sale!!!
I get the impression Corally have only produced a small number of kits thus far.
I know a new batch of UK kits are being prepared.
_____________________
"To finish first, first i must finish!"
www.mkrctc.org.uk
www.akularacing.co.uk
Toblerone is offline   Reply With Quote
Old 07-16-2009, 12:05 PM   #83
That place is basically charging $450 for the car, and then shipping to usa for probably $40. I don't believe that we have to pay VAT if it leaves the country (19% sales tax over there!!)
You would have to want the kit pretty bad to not wait it out.
I'm going to have to get a better idea whats in the new car to decide if its really worthwhile but the chassis and bulkheads probably make the up the majority of the price of the kit.
Old 07-17-2009, 12:20 PM   #84
Send a message via AIM to goop
Originally Posted by ~McSmooth~ View Post
How did that new 50C 7500 Lipo fit in the new car? How much weight did you have to add?
lol
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 07-18-2009, 05:11 AM   #85
crabboy's Avatar
Trader Rating: 58 (98%+)
Hi Guys, im giving my 09 its first run tomorrow, i will do a post and let you all know what the car is like in kit form and any changes i make.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 07-18-2009, 01:40 PM   #86
Rhys
Cool, let us know how it goes.
One thing that is putting me off the car is the small 'user base' especially in the UK, so any set up tips are all welcome.
www.mkrctc.org.uk
Old 07-19-2009, 08:39 AM   #87
crabboy's Avatar
Hi Guys,
Ok i ran the car today with a win in the mod class at our local club, i was running 5200 lipo, Much More 36 tyres, 4.0 SP motor on a large bitumen outdoor track.
Now for the the bits you all want to hear, firstly i run a spool in the front, and when you run that the front bearing holders are reversed from when running a oneway, and there is nothing to stop the bearings from being pushed out of the bearing holders, so after 2 laps both front bearings fell out. There are 2 fixes for this 1) run the alloy bearing holders that are an option part or 2) as i did run a very small bead of glue onto the bearing holder then push the bearing in, this work good and i had no more problems all day.
One thing i think you need to be mindfull of when building the kit is the hindge pin mounting blocks, there is a small rib on the blocks that indicates which way the blocks go, i can see a few bring fitted in reverse if your not paying attention, so keep an eye on your instructions for the correct fitment.
My kit had some excess movement in the hindge area causing the arms to be very loose on the pins, but in the kit there are shims to take the freeplay out of the hindge pins which inturn takes the out freeplay out of the arms, hope you can understand that, its all in the instructions.
On the track i started with standard kit setup and it was not to bad, the car had great steering but the rear was not as planted as i would have liked, i removed the screw and shim from the bulkhead to give a little more chassis flex, shortened the rear wheel base 2mm (one shim) went slightly softer on spring rates, i only made one change at a time so with those changes the racing was over, the car got better with every small change, and will be back at the track next week end for some open practice so i hope to get the car even better.
The car was good enough to give me the overall win in the mod class today on its first outting, so i was happy with that.
Will keep everyone posted on any future changes i make to the car.
Rhys
Rhys Marshall.
Old 07-19-2009, 08:43 AM   #88
Vicko's Avatar
Trader Rating: 14 (100%+)
are the plastic bearing holder the sames as the metal ones from the
Phi 1?
Vicko is offline   Reply With Quote
Old 07-19-2009, 08:44 AM   #89
crabboy's Avatar
Some pics of racing today thanks to Mike Swann.
http://www.rctech.net/forum/6085457-post426.html
Rhys
Rhys Marshall.
Old 07-19-2009, 08:48 AM   #90
crabboy's Avatar
The bearing holders from the Phi 07/08 will fit the Phi 09, the alloy bearing holder has a retainer cilp holding the bearing in so it can't come out, they would be the ones to run in the 09.
Rhys
Phi 1?
Rhys Marshall.
For sale/trade thread UnderDaHill Nebraska/Iowa Racing 5234 12-08-2017 05:01 PM
St Ives RC Club B4Bandit Australian Racing 16584 12-06-2017 03:53 AM
Fastlane Raceway kansasracer Kansas/Missouri Racing 17302 11-12-2017 03:30 PM
Team Corally RDX Phi syndr0me Electric On-Road 3380 03-11-2014 11:27 AM
Corally RDX Phi 2 c1 racin Electric On-Road 52 05-08-2009 02:38 PM
