Old 04-25-2011, 04:30 PM   #661
Trader Rating: 19 (100%+)
Originally Posted by BJohnson View Post
Randy - Just put a 42 tooth spool up front and run the BD5 Gear Diff in the rear. You will end up using the same belts as I had posted earlier.
bd5 gear diff is 40 tooth correct? Thanks
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 04-26-2011, 11:58 AM   #662
BJohnson's Avatar
Yes - the BD5 Gear Diff is a 40 tooth. You should be able to order it from Rob at Superior Hobbies. He is now carrying Spec-R products. Otherwise HKS hobbies on Cali has them in stock.
BJohnson is offline   Reply With Quote
Old 04-26-2011, 12:02 PM   #663
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Brad Johnson.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 04-26-2011, 02:14 PM   #664
Holmenkollen's Avatar
Underdrive?
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 04-26-2011, 03:06 PM   #665
thanks for the info Brad, ill look into it soon. and also, do you know what the actual part number for the belts are?
★Randy Banks★
Old 04-28-2011, 10:45 AM   #666
BD-5 40t SPEC-R diff now ordered looking forward to seeing what a differance it makes to the 09 racing in 17.5 non boosted and boosted.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 04-28-2011, 09:16 PM   #667
okay im stuck, i should know this question but i really need help, my car is hooking to just the right side, i have checked chassis tweak, suspension tweak, spring, tires, shock issues, radio enpoints, droop, camber, any other ideas that i may have missed other then bent hing pins or anything? Thanks
★Randy Banks★
Old 04-28-2011, 10:34 PM   #668
Shop Owner
FTTim's Avatar
Trader Rating: 27 (100%+)
Send a message via AIM to FTTim
Check Your car for blown bearings. More than likely that is your issue.
AWESOMATIX USA | ROCHE USA | TEAM TRINITY
"The man who smiles when things go wrong has thought of someone to blame it on."
"Id rather die on my feet than live on my knees"
FTTim is offline   Reply With Quote
Old 04-29-2011, 01:21 AM   #669
Also look at the spool if you use the Derlin one, I have found when it gets damaged where the blades go in, the car will pull to one side.
XRAY T4 2015 | Hobbywing Club Spec | Thunder Power 21.5
miku is offline   Reply With Quote
Old 04-29-2011, 05:39 AM   #670
thanks for the idea, i actually run the aluminum but thanks anyway
★Randy Banks★
Old 04-29-2011, 05:40 AM   #671
okay thanks, thats one thing i didnt have time to do last night
★Randy Banks★
Old 05-04-2011, 06:13 AM   #672
anybody know where i can get the super narrow chassis upgrade in the united states, im having an issue finding it on the corally USA site (if its even there) or a place i can buy it at all? Thanks in advance
★Randy Banks★
Old 05-04-2011, 08:20 AM   #673
Default chassis
The super narrow chassis is not listed yet, your best bet would be to call Corally USA directly.
XCELL is offline   Reply With Quote
Old 05-04-2011, 03:24 PM   #674
I might do that in a couple of days, i mainly want it for outdoor racing to put on my spare car.
★Randy Banks★
Old 05-21-2011, 06:52 AM   #675
Uziman's Avatar
Wouldn't different size pulleys cause front and rear wheels spin at different rates?
Corally RDXΦ'09 ★ Airtronics/Spektrum ★ Tekin ★ Fantom
★ www.aerccc.org.au ★
Uziman is offline   Reply With Quote
For sale/trade thread UnderDaHill Nebraska/Iowa Racing 5234 12-08-2017 05:01 PM
St Ives RC Club B4Bandit Australian Racing 16584 12-06-2017 03:53 AM
Fastlane Raceway kansasracer Kansas/Missouri Racing 17302 11-12-2017 03:30 PM
Team Corally RDX Phi syndr0me Electric On-Road 3380 03-11-2014 11:27 AM
Corally RDX Phi 2 c1 racin Electric On-Road 52 05-08-2009 02:38 PM
