Old 07-10-2009, 11:30 AM   #46
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Originally Posted by Brian Bosley View Post
Can you use a smaller spur? I run a 76 spur and 43 pinion with 17.5 on the old car.
Yes Brian, a smaller spur is the faster solution, but I would prefer the 78T or 81T spur like I used in the old phi. I think in the old Phi the centre pulley position was not so problematic. Bigger spurs are more efficient. Maybe if I use the option belts from Corally could slightly solve the problem.
(#79135 - Front 510mm/170t)
(#79134 - Rear 210mm/70t)
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 07-10-2009, 01:13 PM   #47
Stusdal's Avatar
The solution you sugest should alow you to pull it back 1-2mm or so. If its not enugh I think you will have to change the center pulley to get it further back. All your alternativs are listed in the manual.
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 07-10-2009, 02:21 PM   #48
So whats the internal ratio of the car folks?
_____________________
"To finish first, first i must finish!"
www.mkrctc.org.uk
www.akularacing.co.uk
Toblerone is offline   Reply With Quote
Old 07-10-2009, 02:26 PM   #49
MSB
MSB's Avatar
Toblerone, from the box is the same as RDX and Phi: 2.0 (42/21)
cheers
Miguel S. Braga
Old 07-10-2009, 06:43 PM   #50
Kenny L's Avatar
Trader Rating: 16 (100%+)
My local hobby store has one Rc excitement if anyone is looking for one.
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 07-10-2009, 06:46 PM   #51
I got the rolling chassis together. Went together smoothly. Diff came out great. Pics to come....Sam
samstheman2 is offline   Reply With Quote
Old 07-12-2009, 01:31 PM   #52
Stusdal's Avatar
Have had to days on the track with the car now. The tip earlier in the thread about putting ceramic bals in the diff right away is solid. I did'nt and its already starting to ruffing up.
Had a coulpe hard meetings with the wall, whitout breaking anything. Althoug it seem the left driveshaft has bent a tiny bit. I've put steel bones on order.
The original front bones is +2mm. Anybody know why? it seems to me that the shorter ones will do just fine. Maybe to keep the oneway outdrives in place?
Old 07-13-2009, 01:21 AM   #53
I wondered about this too, i think the axle lengths for Front and rear driveshafts are different too?
Does the car have a plastic blade type fitting (like on Schumacher and Xray) for the driveshaft end?
www.mkrctc.org.uk
Old 07-13-2009, 05:50 AM   #54
Stusdal's Avatar
Yes, the front bones is +2mm to yhe rear ones. They both have blades fitted.
Old 07-13-2009, 06:11 AM   #55
flashgordon's Avatar
Trader Rating: 27 (100%+)
Talking RDX PHI 09
Hi guys just after some feedback on the new model if it is worth getting one yet and where can i source one not many people seem to have them yet and a rough price guide for them?
Thanks Flashgordon
RDX/PHI 09 Corally-Emtron 30amp Power Supply-KO Helios-Spektrum-Speed Passion
Graphics Alive
M.R.C.C.A...R.I.P
flashgordon is offline   Reply With Quote
Old 07-13-2009, 06:30 AM   #56
imprsme's Avatar
Trader Rating: 74 (99%+)
Well I sat down last night after work to just "get started" on the kit. I couldn't just look at the box any longer...Just as every other Corally kit I have built, it was a dream to build.
I got all the way to the shocks and looked at the clock and it was after midnight. I needed to get up semi-early today so I stopped there.
The New Inner hinge pin mounting system is AWESOME! The only "problem" I ran into was trying to use Alum. steering knuckles and C-hubs. You will still need to use the older C-hub screws, the new ones are to long on the bottom.
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 07-13-2009, 07:46 AM   #57
Default Wheelbase when compared to other Tourers?
Im reckon im getting close to ordering a PHI 09!!
What wheelbase length is the car in standard form? How does it compare to say, an Xray?
Cheers for all the replies folks!
www.mkrctc.org.uk
Old 07-13-2009, 08:26 AM   #58
Has anybody thought of using a different suspension arm set-up on the 09 now that the chassis is set-up for that option? I have seen Marc Fischerís 09prototype and he was testing with the Tamiya set-up, just wanted to know if anybody else has done it yet.
Patrick
XCELL is offline   Reply With Quote
Old 07-13-2009, 08:32 AM   #59
niznai's Avatar
So where is it available now?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-13-2009, 08:44 AM   #60
Trader Rating: 38 (100%+)
What are the benefits of the Phi 09 over the regular Phi? The lipo under the bulk-head/top plate and the much lower price are benefits but what else is there? In some ways it feels like a downgrade.
Do the carbon c-hubs and knuckles fit the original Phi?
or8ital is offline   Reply With Quote
For sale/trade thread UnderDaHill Nebraska/Iowa Racing 5234 12-08-2017 05:01 PM
St Ives RC Club B4Bandit Australian Racing 16584 12-06-2017 03:53 AM
Fastlane Raceway kansasracer Kansas/Missouri Racing 17302 11-12-2017 03:30 PM
Team Corally RDX Phi syndr0me Electric On-Road 3380 03-11-2014 11:27 AM
Corally RDX Phi 2 c1 racin Electric On-Road 52 05-08-2009 02:38 PM
