Old 03-01-2010, 08:20 PM   #466
Still Bill's Avatar
Originally Posted by clparsons123 View Post
when you only have one shock tower it flex to much causing problems plus they break really easy
Having never broken a shock tower on any of my RDX/Phi cars, I must wonder why the 09 version has any such issue???
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-02-2010, 05:17 AM   #467
rcterp's Avatar
Trader Rating: 35 (100%+)
I'm new to this whole Corally thing but the shock tower doesn't feel any weaker or more flexible then my Xray did.
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 03-02-2010, 06:02 AM   #468
rcterp's Avatar
Another question. Are there any weights that fit the six cell chassis to balance and make weight other then the 25g weights? I use the 30g weights that fit under the battery on the lipo chassis but I was looking for something for the six cell chassis.
Φ
Old 03-03-2010, 02:34 AM   #469
I use the PPD Billet weights Link and modified to suit the car. The weight after getting to with a Dremel is 85gms. Refer attached
Regards
Michael
miku is offline   Reply With Quote
Old 03-03-2010, 08:43 AM   #470
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Regards
Michael
I did the kinda the opposite...I ground down the chassis to make the plate fit. You could go either way. Then I just went out and bought the lipo chassis.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 03-03-2010, 08:48 AM   #471
rcterp's Avatar
Thanks guys, sorry for all the questions, but I'm new to the Corally line.
Is there a benefit to the rear body posts being mounted to the bearing holder plate as opposed to the rear shock tower?
Φ
Old 03-03-2010, 08:57 AM   #472
Not really. But what some have done when they do that is to mount front body post on the rear shock tower. They will point straight backwards. This can help prevent body tuck.
http://www.rc50.com/modules.php?name...lbum=63&pos=89
Old 03-04-2010, 06:25 AM   #473
KR145's Avatar
There are several Corally's at our local track and I have not yet seen a broken shock tower or double shock towers.IS this a mod foam thing?( I mean that as going WAY faster that what we are going in 17.5/13.5 rubber classes).I thinkthe Corally's fit,finish and durability are top notch,once you put the alum front steering knuckles on.Love mine.
Kevin Rogers
XRAY Gtx8, Xray T4 '18
RoseCityScaleRacers
KR145 is offline   Reply With Quote
Old 03-04-2010, 08:02 AM   #474
Well the double shock tower also has to do with the flex in the shock tower not just durability. As it has been explained to me, there is too much flex in the rear tower. Doubling up adds rigidity and makes the car more responsive. I am also running the 2.9mm chassis for rubber/carpet for similar reasons.
Old 03-05-2010, 06:34 AM   #475
KR145's Avatar
Ok,that makes more sense than them breaking.I just got my new car a couple weeks ago,having ran the old car for a year or so, so I have alot to learn about the new one.
Is that the 2.9 lipo chassis?
Kevin Rogers
RoseCityScaleRacers
Old 03-05-2010, 07:39 AM   #476
Yep. I really like the weights in the chassis. I can balance my car perfectly with them. Although Brad Johnson says to try add the 25g weight behind the battery. He says it helps offset the weight of the motor. I still need to get one myself.
Brad if I am incorrect, feel free to correct me.
Old 03-07-2010, 01:24 AM   #477
Has anyone got a easy fix to stop the front bearings comming out of the holders?
XRAY T14
www.wingsoverthedowns.com.au
PHI2 is offline   Reply With Quote
Old 03-07-2010, 04:03 AM   #478
Uziman's Avatar
Yes use the alloy phi ones with the circlips
Corally RDXΦ'09 ★ Airtronics/Spektrum ★ Tekin ★ Fantom
★ www.aerccc.org.au ★
Uziman is offline   Reply With Quote
Old 03-07-2010, 04:39 AM   #479
blade072's Avatar
Trader Rating: 98 (100%+)
i still use the standard nylon ones at the rear as they are molded with the lip to hold the bearings in.....but you definately need the front alloy ones..also its recommended to use the alloy steering blocks combined with the alloy c-hubs.....which are thinner and gives you that extra bit of travel (more steering epa)
oh and if you use a spool, try getting the specialized rc bones that use the steel blades......sold separately unfortunately
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 03-07-2010, 05:33 AM   #480
rcterp's Avatar
You can also wedge the clips in the nylon holders.
Φ
For sale/trade thread UnderDaHill Nebraska/Iowa Racing 5234 12-08-2017 05:01 PM
St Ives RC Club B4Bandit Australian Racing 16584 12-06-2017 03:53 AM
Fastlane Raceway kansasracer Kansas/Missouri Racing 17302 11-12-2017 03:30 PM
Team Corally RDX Phi syndr0me Electric On-Road 3380 03-11-2014 11:27 AM
Corally RDX Phi 2 c1 racin Electric On-Road 52 05-08-2009 02:38 PM
