Old 01-10-2010, 08:47 AM   #436
Here is a picture of Marc's car from the DHI cup with the new arms and sway bars up front/rear. He is doing well considering the airline lost all his luggage and all he had in his carry on was his car and radio. Hope the pictures help.
http://events.redrc.net/event-gallery-2010-dhi-cup/
XCELL is offline   Reply With Quote
Old 01-10-2010, 10:23 AM   #437
Damnit Man's Avatar
Send a message via MSN to Damnit Man
Are those Tamiya CVD's on the front of his car?
Donovan P.
Damnit Man is offline   Reply With Quote
Old 01-10-2010, 03:24 PM   #438
s.nicholson's Avatar
Send a message via MSN to s.nicholson Send a message via Skype™ to s.nicholson
I'll post up some pics in the next day or 2, I mounted the old assasin rear bar on the front so that I did not have to remove the front carbon plate, on marc's car he is using the tamiya bars. I used the copper bar in front due to the new leverage points now not like the old arms use to be.
Team Yokomo/Panaracer/LRP/Xenon
Roche/Pro-Spec
Sanwa
s.nicholson is offline   Reply With Quote
Old 01-11-2010, 07:53 PM   #439
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
corally takes 2nd, 4th, 5th and 8th in 13.5 at the novak race.. thanks for the help brad, brian and bill.... see you guys in a couple weeks... jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 01-12-2010, 11:04 PM   #440
I've got my 09 lipo spec and I've got it all set up.
My problem is that the weight diagonally is out.
The left front and right rear are about the same but are much lighter that the front right and left rear. Is this normal? and how can I fix it if it needs to be?
kiwirevo is offline   Reply With Quote
Old 01-13-2010, 01:38 AM   #441
blade072's Avatar
Trader Rating: 98 (100%+)
have you tried balancing the car using balancing points???
have you got any of the corally weights for under the battery and the chassis weights they made for the car???
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 01-13-2010, 03:31 AM   #442
Yeah I've got them all, but I don't need one of the 30gm ones so I took it out of the front. Any other ideas? it is about right side to side but I just think it's odd that it's so far off. I've been using mini scales to measure all 4 corners. I've loosened the springs right off, and also a friend with the same car has the same weight imbalance.
Old 01-13-2010, 05:43 AM   #443
Moderator
J.Whiting's Avatar
you need to use a small servo also. a full sized servo will weight alot more. also add weight all around the car till you get close car should weight between 1470-1510 grams to get the car weight at all 4 corners equal. jeremy
Old 01-13-2010, 03:21 PM   #444
tza1981's Avatar
Which servo do you recommend?
Thanxs
Thomas
tza1981 is offline   Reply With Quote
Old 01-13-2010, 04:51 PM   #445
blade072's Avatar
Thanxs
Thomas
hi thomas
either the kopropo 2413 or the futaba s9551 both are low profile...
yeah forgot so say too had to add weight on each side to balance the car correctly....
i have standard eu kit with 100gm added to battery strap and 15gm in front of the battery to even it up...also have 1 25gm corally weight in one of the slots....
regards
David
David Randall
Old 01-15-2010, 08:06 PM   #446
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
Has anyone used the new straight wishbones? Also what are the parts needed for the top of the shock to extend it in the back? Thx.
mdwaeracer is online now   Reply With Quote
Old 01-15-2010, 08:15 PM   #447
blade072's Avatar
s.nicholson has you might want to pm him mate...
David Randall
Old 01-15-2010, 08:25 PM   #448
Moderator
J.Whiting's Avatar
not yet getting them installed right now and test/race if time allows me to. if not sunday will be the first time on the arms.... i am putting the shocks in front of the shock tower but looks like 20mm spacers will be about correct to make angles stright up and down with the long shock bottom studs... with shoert shock bottom studs about 15mm spacers. a peice of aluminum hollow tubing from menards or home depot is what i used at first then change things back. here are a couple quick pics.. jeremy
Corally RDX Phi 09-corally-phi-09-002.jpg   Corally RDX Phi 09-corally-phi-09-003.jpg   Corally RDX Phi 09-corally-phi-09-001.jpg   Corally RDX Phi 09-corally-phi-09-004.jpg   Corally RDX Phi 09-corally-phi-09-006.jpg
Old 01-21-2010, 08:37 AM   #449
MAD916's Avatar
Got the new arms on last week and ran the cars this last weekend at Round #3 of the NWIC. Richard St. Cyr took the win and almost TQ'd 13.5 Rubber. cars are awesome. Went to a longer wheel base to help get the balance right, used the shorter camber link mounts off the RDX in the rear, to straighten them out, also running the small pulleys 1.71 which helps line up the rear diff.
Great car transitions quickly, great steering, still very tough, holds a setup/tweak, and is smooth as silk. On my way to the Birds with an all freshened up ride.
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 02-14-2010, 04:08 PM   #450
Victor Vector's Avatar
Any Snowbird Research ?? Set up sheets ?? Latest and Greatest ??
Got my new ride and need clues please................
Jacko
Jack Balchin.
Timezone Hooligan
IBEW Local 48-retired (Definitely, great pension.)
Victor Vector is offline   Reply With Quote
For sale/trade thread UnderDaHill Nebraska/Iowa Racing 5234 12-08-2017 05:01 PM
St Ives RC Club B4Bandit Australian Racing 16584 12-06-2017 03:53 AM
Fastlane Raceway kansasracer Kansas/Missouri Racing 17302 11-12-2017 03:30 PM
Team Corally RDX Phi syndr0me Electric On-Road 3380 03-11-2014 11:27 AM
Corally RDX Phi 2 c1 racin Electric On-Road 52 05-08-2009 02:38 PM
