Old 07-09-2009, 04:40 PM   #31
Originally Posted by Toblerone View Post
I too would like to see some more pics please of peoples RDX Phi 09's if anyone has them.
Im thinking about getting an Phi 09 for stock racing in the UK
I'll have some pics(hopefully) after a finish building mine in a couple days.
Sam
samstheman2 is offline   Reply With Quote
Old 07-09-2009, 05:26 PM   #32
Stusdal's Avatar
Originally Posted by Holmenkollen View Post
Here you go. Its a bit modified with shocks behind shock tower and short wheelbase. Im starting to get a ok base setup.
In what way does shock behind shocktower effect the handeling of the car?
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 07-09-2009, 10:16 PM   #33
Jeff Brown's Avatar
Originally Posted by Rommel View Post
Is the carbon fiber chassis itself any different than the last RDX PHI?
Yes, the chassis itself is quite different. Wider in a lot of places from the previous car.
Jeff Brown is offline   Reply With Quote
Old 07-09-2009, 10:18 PM   #34
Jeff Brown's Avatar
Well, the first batch was received and shipped out. Quite a small shipment. The first kits were EU rubber spec and we hope to see some US Foam kits with the next shipment.
The next shipment will most likely be the first of August so place your backorders now as we do not know the amount of kits we will receive. Vegas is not far off and I know people are looking to get their kits built.
The list is so short I do not have one.
Old 07-10-2009, 12:25 AM   #35
Sam
Cheers Sam.
Let us know how the build goes - im mainly used to building Schumacher kits, so the Corally would be a big change for me!!
Toblerone is offline   Reply With Quote
Old 07-10-2009, 01:57 AM   #36
Holmenkollen's Avatar
Better feeling and better rotation.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 07-10-2009, 07:23 AM   #37
Well just finished looking through all the parts and realized the car has no diff. So pics will be a while.....
But the shop owner called Corally and they quickly made it right...Thanks!
Old 07-10-2009, 07:25 AM   #38
That sucks
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-10-2009, 07:27 AM   #39
Originally Posted by SRW141 View Post
That sucks
yea too bad.
Old 07-10-2009, 07:31 AM   #40
Trader Rating: 38 (100%+)
WOW. That stinks. I had a buggy come with 3 rear wheels and only one front wheel once but this sounds a lot worse.
or8ital is offline   Reply With Quote
Old 07-10-2009, 09:26 AM   #41
The Teacher's Avatar
Trader Rating: 49 (100%+)
Samnizzle, stop bitching and get to work......I'm sure the guys at Corally will hook you up...
The Teacher is offline   Reply With Quote
Old 07-10-2009, 10:12 AM   #42
We had 3 kits arrive here yesterday, all 3 sold. The first kit went together with no issues and was quite an easy build. The proud new PHI owner ( his first TC Kit), built the kit in around 6 hours with no issues.
The second kit has had no build issues either. 2 of them should be on the carpet by Sunday and the 3rd went to NJ.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 07-10-2009, 10:22 AM   #43
My kit was missing one bladder and a couple of ball studs. Too much partying at the Corally factory.
Old 07-10-2009, 10:43 AM   #44
MSB
MSB's Avatar
Send a message via Yahoo to MSB
One thing that I noticed after assembled is the axle of centre pulleys and spur gear are positioned at the front. This position disable to use big pinions for stock classes.
Is there any solution to solve this, e.g. use other belts (bigger in front, shorter in the rear)?
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 07-10-2009, 10:48 AM   #45
Can you use a smaller spur? I run a 76 spur and 43 pinion with 17.5 on the old car.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
For sale/trade thread UnderDaHill Nebraska/Iowa Racing 5234 12-08-2017 05:01 PM
St Ives RC Club B4Bandit Australian Racing 16584 12-06-2017 03:53 AM
Fastlane Raceway kansasracer Kansas/Missouri Racing 17302 11-12-2017 03:30 PM
Team Corally RDX Phi syndr0me Electric On-Road 3380 03-11-2014 11:27 AM
Corally RDX Phi 2 c1 racin Electric On-Road 52 05-08-2009 02:38 PM
