Corally RDX Phi 09
#376
Having great success with this Phi 09 Rubber setup for high bite carpet tracks.
Front:
Ride Height: 5.25mm
Spring: 24.5
Oil: 60wt
Shock Position: second hole in on top. out on bottom
Camber link: up and in
Toe: 0
Ackerman: plus 1mm shim
Camber: -1.75
Up travel: 1.5mm
center wheel base white shims
track width: 190mm
Rear:
Ride Height: 5.5mm
Spring: 17.0
Oil: 40wt
Shock Position: third hole in on top. out on bottom
Camber link: up and 2nd hole in
Toe: 3 in
Camber: -2.75
Up travel: 2.5mm
short wheel base white shims
track width: 188mm
13.5 Ballistic 5.9 FDR Tekin v200
seems to be working great, just ran my fastest laps to date and very close to our local fast guys quickest times. Still working on front to rear balance seems to still be a bit heavy to the rear of the car, it seems to really swing around the front end when changing directions through the chicane's.
Front:
Ride Height: 5.25mm
Spring: 24.5
Oil: 60wt
Toe: 0
Camber: -1.75
Up travel: 1.5mm
track width: 190mm
Rear:
Ride Height: 5.5mm
Spring: 17.0
Oil: 40wt
Toe: 3 in
Camber: -2.75
Up travel: 2.5mm
track width: 188mm
#377
ANYONE HAVE REAR BULKHEAD BRACKET FOR A PHI 07, THE PART THAT BOLTS TO THE BULKHEAD AND HOLDS THE BODY POSTS
IM INTERESTED IN TWO IF ANYONE HAS SPARES
#378
Hey guys - Corally USA is going to post some Phi 09 rubber tire carpet setups on the website. They should be updated with in the next day.
Thanks - Brad
Thanks - Brad
#380
#381
I believe the car is a little heavy towards the rear. I have added roughly 25 grams of weight to the front of the car between the bulkheads directly behind the bumper. This added weight to the nose of the car has helped with intial turn in as well as slowed down the "swing" of the rear end.
#382
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
#383
I'll give you a call sometime as I have other questions.
#384
Does the TC 01620
CORALLY RDX PHI '09 - "LIPO OPTIMIZED"
Comes with the brass weights that are shown on the picture thats on the Corally site ?
Just have orderd mine it's cold here and as i drive normally offroad wanted some fun in warm area's where i still could drive
#387
I can't even find this on their website...
Does the TC 01620
#388
Ahhh, I was one the corallyusa site...
