Old 09-18-2009, 11:06 AM   #256
Holmenkollen's Avatar
Originally Posted by samstheman2 View Post
What I use with the small pulleys are the optional bearing holders and the Corally short rear belt. This works fine.
If you want to use 36/18 pulleys with the car just buy the optional 186 mm rear belt and use the standard front belt. This is with standard wheelbase.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 09-18-2009, 11:16 AM   #257
clparsons123's Avatar
so is there any benefit from running the smaller pullys? other then the fact you can run the shorter wheel base?!
EAM (TEAM EA MOTORSPORTS),ORCA, RC AMERICA, XRAY,HUDY,EZ CUSTOMS, RSD (REFLEX RACING) , JEFFS RC STUDIO, RCTVLIVE
Cory parsons
clparsons123 is offline   Reply With Quote
Old 09-28-2009, 10:02 AM   #258
Stusdal's Avatar
Originally Posted by Stusdal View Post
Yes, super short WB is what i wan't. I have now the 416 belt and that is not fitting, the part number from yours is from the 415. I will get my hands on one of those and try again
I finally got it right. The 415 belt is 177mm - it fits but its tight, and I couldent get it as free as i wanted.
Got the belt from the 415MSX MR, it is 180mm and fits perfect part number 6245014.
Now, lets hope this gives me an advantage on the tight indoor tracks
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 09-28-2009, 08:18 PM   #259
Still Bill's Avatar
Gives you a higher final drive ratio (FDR) for brushless motors...perfect! Allows you to run reasonably sized spur gears (for better gearing options...less differential between gearing changes).
FYI...I use the shorter wheelbase on both carpet and asphalt with my original Phi. It is the bong for all my local tracks!
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 09-29-2009, 11:50 AM   #260
Stusdal's Avatar
US spec is ready:
"LIPO OPTIMIZED" - #TC 01620
"LIPO OPTIMIZED" US CARPET SPEC - #TC 01621
Old 09-29-2009, 05:19 PM   #261
ok. thanks still bill
well this past weekend i tqed and won 17.5 at the first state race with the phi 09 here in florida. it was only the second race on the car.
but does anyone have setups wrote down? if so can you post them it would be awesome. i'll post my setup soon
thanks
cory
Cory parsons
Old 09-29-2009, 07:17 PM   #262
B4james's Avatar
Below is my PHI 09 17.5 Stock Asphalt rubber tire set up, I used this set up to win the South Australian State Titles this month.
Shocks:
Front: Tamiya Shocks
17lb Corally 3 Hole piston 50 Weight Corally oil
Inner most hole on tower and outside on arm
Rear: Tamiya Shocks
14lb Corally 3 Hole piston 40 Weight Corally oil
2nd hole from inner on tower and middle on arm.
Ride Height:
Front: 5.5mm
Rear: 6mm
Silver sway bars on front and rear, spool front
Wheelbase:
Front: Short (both spacers in front)
Rear: Middle
Camber:
Front 1.5
Rear:1.5
Front and Rear Arm toe Kit settings
2.0mm spacer under rear camber link (Hub side)
Camber links front and rear in the lowest inner holes.
100g of weight on outside of lipo packs
2 x 30g Corally weights in chassis slot locations.
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 09-29-2009, 07:47 PM   #263
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
What gear ratio or you running for your 17.5 setup
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 09-29-2009, 07:54 PM   #264
Still Bill's Avatar
Better ask what ESC he has too.
Old 09-29-2009, 08:03 PM   #265
dfiantii's Avatar
Good point. I have the regular RDX and was just wondeirng what gearing your using. I am going to start the WCGT Class and of course the RDX thread is dead so I read this one. I have a SpeedPassion 2.0GT in my car.
TLR 22 2.0
Old 09-29-2009, 08:08 PM   #266
B4james's Avatar
I am running the Tekin RS speedy and Trinity DUO 1 motor,
0 Degrees on the motor
25 Boost
Max Turbo and depending on track size 1 to 1.8 seconds on the turbo delay
FDR Varies from big track at 3.6:1 and smaller tracks 4.1:1
Our smaller tracks are probably about a mid size USA track and our big tracks are big 1/8 nitro tracks.
Old 09-29-2009, 08:14 PM   #267
dfiantii's Avatar
You guys should post pics of your setups. I just purchased a FANTOM DUO 2 today for my setup.
TLR 22 2.0
Old 09-30-2009, 02:39 PM   #268
Default handling
does the 09 need to be weighted to handle correctly if so where and also what pinion should i use i have standard internal ratio with an 8.5 novak and novak xbr speedo i run on carpet small track haif the size of a sports hall cheers
the daddy is offline   Reply With Quote
Old 09-30-2009, 05:21 PM   #269
Asphalt Nationals start on Friday. I will post a high bite asphalt setup after this weekend. Should be a decent Corally showing.
samstheman2 is offline   Reply With Quote
Old 09-30-2009, 06:18 PM   #270
yeah mike b tj b and brad j are up at nats running 13.5 . its going to be a good race.
my setup for 17.5
front corally shocks with 14.5 lbs springs
30 weight ae oil
stk pistons
rear corally shocks with 17.0 lbs springs
30 weight ae oil
stk pistons
shock postions
front
1 from all the way down
all the way out on the arm
rear
1 from all the way up
in the middle on the arm
upper links are all the way in and up on the front and rear shock tower
on the rear middle hole on the alm rdx rear up rights
front 1 degree toe out
rear 2 degree toe in on each side
droop
front + rear
5
top deck cutout - phi symble
alm steering nuckels
alm c hubs 4 degrees
alm rdx rear uprights
camber
front+rear
1.5 degrees
short wheel base
front + rear
anti squat in the rear
one thick shim under the front rear blocks
motor= novak ss pro all timing in motor
speedo= spx on mode 7
fdr at a 4.50
Cory parsons
For sale/trade thread UnderDaHill Nebraska/Iowa Racing 5234 12-08-2017 05:01 PM
St Ives RC Club B4Bandit Australian Racing 16584 12-06-2017 03:53 AM
Fastlane Raceway kansasracer Kansas/Missouri Racing 17302 11-12-2017 03:30 PM
Team Corally RDX Phi syndr0me Electric On-Road 3380 03-11-2014 11:27 AM
Corally RDX Phi 2 c1 racin Electric On-Road 52 05-08-2009 02:38 PM
