13.5 SEDAN GEARING
Hello,I was looking for a good starting point to gear a 13.5 in the foam tire sedan class? I will be running a TRF 415 and the track size is like 60x90.64p gears will be used.Thanks
what speedo are you useing .myself run between 4.5 to 5.4 on a speedpasion gt2 with a duo motor
LRP TC SPEC:nod:
anything between a 47 - 54mm roll out
I have run a highest of 53.6 witha SP GT 2.0 and SP 17.5 with motor just over 60 deg/c Start conservatively geared and keep gearing up till motor temps around 65 deg/c after 5 mins and you can gauge from lap times and performance feel. Always nice to have a few cars to run against. |
