Old 01-22-2004, 08:49 PM   #31
TexasRacer's Avatar
Send a message via AIM to TexasRacer
I just shaved every other tooth on the diff on the xray to try that out instead of doing it on the belt doing it to the belt will make it alot weeker.
TexasRacer is offline   Reply With Quote
Old 01-23-2004, 12:16 AM   #32
Tek Nickal's Avatar
Originally posted by SalvadoriRacing
AzNDRAGster,
this helps to get a lower friction transmission???
Yes, teflon will stay on the belt and will act as a luberacant to the belts. I have done this on belts, shaft gears, spur gears, ect.
Tek Nickal is offline   Reply With Quote
Old 01-23-2004, 01:34 AM   #33
Cole Trickle's Avatar
I wonder why there's no teflon treated pullies on the market?
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 01-23-2004, 09:09 AM   #34
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
azndragster.......
what teflon oil do you use and/or recommend??????
how long should i dip the pulleys and belt in the oil???
only coating the belts and pulleys with oil will work well or I have to dip them in the oil to do the best job????
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 01-23-2004, 10:38 AM   #35
AN
SalvadoriRacing: Spray the belt with teflon spray
/AN
AN is offline   Reply With Quote
Old 01-23-2004, 11:11 AM   #36
HYDRAMATIC99's Avatar
Send a message via AIM to HYDRAMATIC99
TexasRacer, have you had a chance to run your xray with the modified belt?
HYDRAMATIC99 is offline   Reply With Quote
Old 01-23-2004, 01:36 PM   #37
Angry
i bought 3mm belts.....
the supplier i found doesn't cut the belts narrower than 3mm....
but it's ok....
i'll try to run these belts, but it seems to be cut by a blind man!!!
uhaahuauauahuhahahahauhahau!!!
the belts are a little crooked, I think they don't have the best equipment to cut a narrow width with precision......
Salvadori Racing
Old 01-23-2004, 03:04 PM   #38
/AN
AN.....
do you recommend any brand or model???
do you know a website/webstore????
Salvadori Racing
Old 01-23-2004, 04:31 PM   #39
TexasRacer's Avatar
Nope I actually didnt mod the belt I did it to the Diffs instead. I will be running them this weekend to let you know how it goes so far it feels alot better.
Old 01-23-2004, 07:55 PM   #40
Tek Nickal's Avatar
azndragster.......
I dipped the pulleys overnight, I dipped the belts for a LONNG time.
Use a bike chain lube with teflon.
Old 01-23-2004, 08:21 PM   #41
ok....thankz.....
i already was thinking about buy the FINISH LINE teflon "dry" oil for chain bike.....
i also saw some plastic unmolding teflon spray......but i'll try the oil.....
Salvadori Racing
Old 06-09-2005, 09:01 AM   #42
Barry White's Avatar
I think you can better soften a belt that lube it.
Barry White is offline   Reply With Quote
Old 06-09-2005, 08:43 PM   #43
speedxl's Avatar
R/C Tech Charter Subscriber
just cut every other tooth on the diffs and use silicone spray or bicycle teflon oil the is weather proof type, armorall tire dressing works great.
Salvadori the rear belt on an xray is 3 mm and will work on a schumacher mi2 note that the thin 4mm schuie belt can snap with anything more powerful then 19t motor! so I dont know how it would hold up on a schui!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 06-09-2005, 08:58 PM   #44
thaks guys,
but i've switched to shaft cars.....
Salvadori Racing
Tricks??? jmdv Nitro Off-Road 5 12-18-2007 08:52 AM
XXX-4 tips and tricks RussB Electric Off-Road 8 11-15-2006 02:29 PM
Tire Tip & Tricks anthony390 Electric On-Road 10 10-14-2005 06:45 PM
Up to my old tricks again........ GundamWZero Chat Lounge 2 09-09-2004 08:40 AM
esc tricks pro3racer Electric On-Road 6 02-27-2004 02:34 PM
