Old 06-03-2009, 10:15 AM   #1
SoCalMitch's Avatar
Default 1/10 WGT Gearing
Just built a RC10R5 with 1-Cell, Novak 13.5, LRP SPX, and 55mm tires.
What pinion and spur should I be shooting for with the 1 cell lipo?
SoCalMitch is offline   Reply With Quote
Old 06-03-2009, 11:47 AM   #2
Trader Rating: 16 (94%+)
You need an 88-Spur with a 40-Pinion to reach an 80mm rollout. Rollout for 13.5 WGT 1-cell is between 75-85mm.
kn7671 is offline   Reply With Quote
Old 06-03-2009, 01:17 PM   #3
I don't know about the roll out but my tires were trued to 2.25 (jaco Purple fronts and pink rears) 44/45 x 88 at most of the tracks here in florida.Just watch your motor temp.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 06-03-2009, 01:47 PM   #4
SoCalMitch's Avatar
Your roll out would be 89.77 with a 44 x 88.
Old 06-03-2009, 01:52 PM   #5
racer/rc's Avatar
Smile
just put my crc gen-x 10 wgt together gonna run 17.5 on 2 cell lipo any ideal what gearing i should start with I am new to this type of racing and have no ideal where to start
racer/rc is offline   Reply With Quote
Old 06-03-2009, 04:07 PM   #6
We run that combo up here in SCAR class in London Canada. We run a rollout of 59 to 62 MMPR outside. One of our most popular classes check it out LondonRC.com.
croz is offline   Reply With Quote
Old 06-04-2009, 07:17 AM   #7
fla racer57's Avatar
Trader Rating: 1 (67%+)
If you want a roll out chart i have it on a spread sheet
fla racer57 is offline   Reply With Quote
Old 06-05-2009, 04:53 AM   #8
LOW ET's Avatar
Trader Rating: 97 (100%+)
is the rollout that much different from nimh and 1c lipo? nimh is about 61-62mm and you guys are saying 75-85mm with 1c lipo.
LOW ET is offline   Reply With Quote
Old 06-05-2009, 06:35 AM   #9
We have been finding 1s LiPo 1/12 and WGT gearing to be about 5-10mm greater than their NiMH counterparts.
For example, we were gearing 1/12 NiMH 17.5 cars around 85mm rollout, +/- 5mm, but now with 1/12 LiPo 17.5 we jumped to a 95mm rollout, +/- 5mm.
You might actually be too low with 61-62mm in NiMH 13.5 WGT, as we were typically in the 65-75mm range with NiMH 13.5. If you race at a smaller track, this may be the reason for your gearing. The track I race at is about 110' x 70'.
Old 06-05-2009, 06:50 AM   #10
LOW ET's Avatar
nimh setups
setup from snowbirds
35/96 gear with 53.34mm tires = 61.09mm rollout using gearchart.com
setup from iic vegas
35/96 with 55mm tires = 63mm rollout using gearchart.com
Old 05-26-2011, 10:57 AM   #11
Layin' Wood's Avatar
Any suggested gearing for WGT 13.5 stock spec 1s motor timing all the way up? We usually run them open with a Tekin at 39/96 and Duo 3 motor with 0 timing.
Layin' Wood is offline   Reply With Quote
Old 05-26-2011, 04:38 PM   #12
Suspended
Trader Rating: 86 (100%+)
does anyone have gearing chart for wgt ?
littlealex is offline   Reply With Quote
Old 05-26-2011, 05:34 PM   #13
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
www.gearchart.com make your own with different tire size
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-26-2011, 08:20 PM   #14
Chubba's Avatar
Hi there, I will be testing my new pan car this weekend and planning to run 7.5t motor. The track is outdoor where I usually play 1:8 nitro so fairly large.
I was wondering what gearing I should start to use and please confirm 64 or 48 pitch gearing.
Tires I will be using are 61mm.
[Mugen MRX 5] [Yokomo R12] [Xray T3 2011] [Xray X10 Link] [KM HK-1]
Chubba is offline   Reply With Quote
Old 05-27-2011, 02:56 AM   #15
andrew-01's Avatar
Trader Rating: 22 (100%+)
EDIT: just saw the date, didn't realize this was bumped from the stone age....my bad
ANDRXW.com
andrew-01 is offline   Reply With Quote
