GM Speedo Help!! >
GM Speedo Help!!
GM Speedo Help!!
Old 12-28-2003, 06:29 PM
Trader Rating: 53 (100%+)
Default GM Speedo Help!!
Hey guys, I have a GM VR4 Esc that never really worked right. I hooked it up, and it only goes reverse. From then I through it in a parts box and never thought about it. Got out of the hobby for a couple months, and now I'm back. Is there any place in the US that I can send it to for service? Can I reset the memory on it maybe?
Any ideas on how to get a GM esc fixed?
Brett
weirdodude13 is offline
Old 12-28-2003, 06:35 PM
JusBox's Avatar
Maybe horizon hobbies? Don't they fix GM?
JusBox is offline
Old 12-28-2003, 06:56 PM
Default timing
maybe the timing is backwards or you wired the tabs wrong try to turn the endball 180 degrees and see if it goes fowrd.
big_bg is offline
Old 01-11-2004, 04:18 PM
dsrbltoys's Avatar
I believe this one does not have a set button. Each time you turn it on, you have to pull throttle first to set the throttle parameters!
dsrbltoys is offline
Old 01-11-2004, 05:27 PM
Well I sent it into GM (Horizon). We will see what happens.
Brett
