Old 05-31-2009, 04:58 PM   #1
Siccmade's Avatar
Default Whats the best way to discharge batteries?
I am wanting to discharge some of my batteries i have some old school 1500mah and some 2000 mah how do i discharge them?
Siccmade is offline   Reply With Quote
Old 05-31-2009, 09:05 PM   #2
Toh WL's Avatar
Buy a good charger that comes with discharger. You can set the discharge current & cut of at any particular Volts you required.
Toh WL is offline   Reply With Quote
Old 06-01-2009, 02:34 AM   #3
V_28's Avatar
get a 30watt-50watt light bulb from the local 2 dollar shop, solder some wires to it and the other side to dean plugs, and connect battery. you can use a multimeter to check the voltage too if you want to discharge precisely or you can see the light dim, which is also a good indication to pull it off. careful though, it generates a whole lot of heat. i say 40 watt or 50, well thats what i use from recommended people. hope that kinda helps?
V_28 is offline   Reply With Quote
Old 06-01-2009, 02:35 AM   #4
V_28's Avatar
....but i would personally get a charger that offers discharge - slightly safer and definately more accurate. my other method is cheaper though
Old 06-01-2009, 07:26 AM   #5
Siccmade's Avatar
Thanks for the info
Old 06-01-2009, 08:37 AM   #6
V_28's Avatar
no prob. i replied to your pm, hopefully you can see the pic there and it makes sense? if not, i'll save a pic and send to you if you need extra help.
Old 06-01-2009, 05:55 PM   #7
Siccmade's Avatar
ok thanks ill try it out
Old 06-02-2009, 08:31 AM   #8
thats what i do. it works really well
elementforlife is offline   Reply With Quote
Old 06-02-2009, 09:18 AM   #9
94eg!'s Avatar
Trader Rating: 17 (100%+)
I picked up a used Integy Reactor 20amp fast discharger off eBay for $.99. They also make a 30amp version. Then I got two Trinity D-90 equalizers for $15. All feature a .9v per cell cutoff, so you know they are Nimh safe.
I always equalize before I charge...
BTW: The D-90 Equalizers are tricky cause they come with no instructions. The battery can only be inserted one way to get it to turn on. On top of that, you must insert the side with the end-bars first. Once you get it, it works every time...
94eg! is offline   Reply With Quote
Newbies Queries - Ask and you shall be answered! renben Singapore R/C Racers 4621 12-02-2017 09:30 PM
Townsville Racing - TMORC Forum Sam Contarino Australian Racing 13652 06-16-2015 07:49 AM
Fusion Batteries John Malin Team and Company Discussions 1827 05-15-2013 09:48 PM
SMC 40C+ C-Max 7.4V Hardcase Lipos Danny/SMC Electric On-Road 430 02-19-2010 07:52 AM
Best way to discharge bear27 Electric On-Road 12 01-31-2006 07:01 AM
