Team Orion V2 Revolution Dyno-Test
Hello Racers
can someone tell me: which Power - and Speed Data does the V2 Revolution 12x1 HT Motor have, when you test it on the dyno with the sprint brushes inside.
Greetings,
Sebi
Greetings,
Sebi
Registered User
Ive only tested mine when i first had it with enduro brushes (ive got sprints now and will test it soon)
I got;
241.5 watts
79.6% eff
42165 rpm
Hope this helps,
Ben
I got;
241.5 watts
79.6% eff
42165 rpm
Hope this helps,
Ben
Hello Ben,
thanx for your data information.
Greetings,
Sebi
Greetings,
Sebi
Registered User
Yep that was a 12x1 HT with enduro brushes. Ive got sprints on it now and its much better!
Ben
Ben
Hy Ben,
have you tested toe V2 with the sprint brushes on the dyno ???
what dyno was that on?
R/C Tech Founder
What kind of power supply are you using to pull low-wind motors on a dyno?
A lot of people I know (in TC racing, at least) don't do much (or any) dyno testing on mod motors, under the logic that it is pretty inaccurate.
Shane, I use a standard lead-acid battery for my Robitronics.
There's nothing wrong with dyno'ing 12 turns, I dyno 10 turns and get consistant numbers. I hope that's not a Robitronics dyno he got those numbers from though, because if it is I need to do some serious work on my 10x2 Ti's.
I mostly dyno mods just to see if they're bad - it's nice to know which of my motors are going to work well on the track, and which of them have something wrong.
Registered User
The tests were done on a CS Electronic Dyno, and used a 6cell pack of 2nd gen. 33's as its power source. I have the sprint brushes installed and will dyno it soon, i will let you know!
The numbers seem to be really good, but on the track i have to say its not my fastest motor, but that one (a peak carrera 12x2), doesnt show up as good on the dyno. I am experimenting to find the right settings for this motor!
Ben
oh yea just in case you wanted to know my carrera pulls 42,095 rpm, 211watts, and is 79.1 % eff.
Ben
R/C Tech Founder
Speedo, yea, I just use a battery for mine as well (thanks Kraig!)
Registered User
In reply to futureal's post i dont dyno my motors that often as it proves to a inconsistant etc, instead i use my pulsar to tell me what amps it is pulling to get an idea when comparing motors. I do however like to put new motors on the dyno just to see what they are made of!
Ben
Ben
Hy Ben,
Registered User
No sorry Sebi i havent yet. I will starting work on my car again next week and so we let you know. INdications on the track shows that its has a lot more punch then the enduros, but topend stays roughly the same. Im on 10runs so far and counting!
Ben
Ben
