Old 05-23-2009, 02:34 PM   #1
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default chassi protective coatings
does anyone have a link to the protective coating for my chassi thanks for info
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 05-23-2009, 02:44 PM   #2
c-lyon's Avatar
This forum under Touring car custom cut urethane chassis protectors might help.
c-lyon is offline   Reply With Quote
Old 05-23-2009, 09:33 PM   #3
just get a rectangular piece of plastic(like you get off toy boxes), and trace your chassis onto it with a whiteboard marker. then cut it and two way tape it to the bottom of your chassis(or use the existing chassis screws to hold it in place).
i did this with my cen ct5-s, and its bottomed out heaps of times, and hasnt worn through the plastic. and no stones get into the driveline.
total3d is offline   Reply With Quote
Old 05-23-2009, 09:38 PM   #4
thisguy2849's Avatar
The problem with your idea is if you dont cut out all the openings to match your chassis is you WILL over heat your electronics
thisguy2849 is offline   Reply With Quote
Old 05-24-2009, 01:10 AM   #5
SWTour's Avatar
Try some of THIS
Surface Guard / Helicopter Tape
Surface Guard Tape is a clear protective urethane film that is virtually invisible to the naked eye. Surface Guard will protect any surface that is prone to scratching, chipping, and weathering. A bullet proof, clear film that provides indestructible protection. Surface Guard has a semi permanent adhesive, with a removable release liner. Available in two different outdoor grades: 8 mil or 14 mil thicknesses. Surface Guard Tape provides excellent protection against ultra violet light, temperature extremes and automotive solvents. Will not yellow over time. Be sure to take note that our Surface Guard Tape is made of Polyurethane Material, not PVC or Vinyl. These other types don't conform well, and also cannot, will not, take the abuse that polyurethane will.
http://www.racerstape.com/rtp.html
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 05-24-2009, 03:56 AM   #6
Send a message via MSN to Missy
You could try light skins or body skin from a auto supply store it comes in sheets about 300mm wide.
Rod
Missy is offline   Reply With Quote
Old 05-24-2009, 04:08 PM   #7
Try Clear Contact paper (not really paper). You can get it at a hardware store.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 05-24-2009, 04:37 PM   #8
DHC6's Avatar
You can also try Losi Chassis Protection material
http://cgi.ebay.com/Losi-Chassis-Pro...lenotsupported
Works great for me.
Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return - Leonardo da Vinci
DHC6 is offline   Reply With Quote
Old 05-24-2009, 04:37 PM   #9
Trader Rating: 68 (100%+)
Send a message via AIM to joey
use this, stick it to the chassis.. trim it to match the shape of chassis
then cut out the screw holes. i only cut out the screw holes i actually use..
http://www3.towerhobbies.com/cgi-bin...?&I=LXSXV1&P=7
=Joe Wright=
joey is offline   Reply With Quote
Old 05-24-2009, 06:27 PM   #10
94eg!'s Avatar
Trader Rating: 17 (100%+)
There is a seller on here selling chassis protector film for pretty cheap. I think I got 5 large sheets for $10 shipped. It's just like clear bra film you get at the autoparts store, but much cheaper. Cut a sheet about the size of the chassis and stick it on (after cleaning the chassis of course). Then trace around all the edges with an x-acto blade. Takes about a half hour and works perfect...
It's best to cut out screw holes, but not 100% necessary. If it's covering the screws, simply poke your hex drive through and loosen the screws. The film won't peel up if you loosen each screw a little at a time.
94eg! is offline   Reply With Quote
Old 05-24-2009, 06:48 PM   #11
qcrc's Avatar
Try this stuff from Rommel, he has sheets for several chassis. All of the screw holes and openings are already cut out for you. I have used them on two of my cars and it holds up really well.
www.rommelsrcworld.com/servlet/StoreFront
https://www.facebook.com/ISLANDSPEEWAY/
qcrc is online now   Reply With Quote
Old 05-24-2009, 07:43 PM   #12
2056dennis's Avatar
Default chassi protector
thanks for all info
Old 05-24-2009, 08:23 PM   #13
YmeBP's Avatar
Trader Rating: 32 (100%+)
I have tried the losi and associated chassis stuff and it's o.k. but this stuff from rommelsworld is the best. It doesn't screw with your droop setting.s
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 05-24-2009, 10:43 PM   #14
Jochim_18's Avatar
I've given up on chassis protector it will just cost you some money. That just how asphalt racing go. I've tried different type of chassis protector they wear out so quick and at $20 a pop might out as well just save your money for a new chassis. You have to replace it in a long run anyways. Just a thought!!!
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 05-24-2009, 11:58 PM   #15
i have air intakes on my electronics, which capture air from the top of the car.
on my electric i just used race tape on some areas, and left the motor side uncovered to get more air to the electronics.
but on the nitro i covered it all up, to stop stones destroying the belts. works pretty well.
