Old 05-19-2009, 11:51 PM   #1
Default Motor and spray lube
Do you experts think that applying spray lube is necessary inside a motor? Is there any harm or good? I am referring to something like the well-known WD-40. Appreciate for your advice.
xniperliams is offline   Reply With Quote
Old 05-20-2009, 12:14 AM   #2
niznai's Avatar
I am not an expert but WD 40 is not what you're looking for. Actually quite the opposite. For cleaning try some sort of alcohol (there's plenty on offer for various jobs but they mainly rely on two alcohols, either methyl or isopropylic, either will do, just read the can and buy the cheaper). Buggy blast is just one of these (I think is isopropylic) but is not the cheapest option. Brake cleaner, electronic spray cleaner, etc are the same thing and some are cheaper depending on brand, etc. Just make sure you use something that doesn't leave any residue.
For lubrication you need either bushing oil or bearing oil both offerred in various forms each with their cohorts of fans. In principle bushing oil is a light machine oil, bearing oil is pretty close, a bit thicker.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-20-2009, 12:16 AM   #3
Thanks for the info. But what is wrong with WD-40? Isn't that some kind of oil in spray application?
Old 05-20-2009, 12:47 AM   #4
niznai's Avatar
Leaves a residue (oil) all over the windings and comm and that can't be good. It heats up and helps things burn out and can't be good on the comm.
Team Greasy Weasel
Tamiya mini series (M01, M02, M03, M04...) mailboxck Electric On-Road 68 08-15-2017 07:00 AM
Tamiya TB-Evolution III rc-zombies Electric On-Road 7237 11-16-2016 06:09 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 09:15 AM
23T motor thread davioh Electric On-Road 1263 08-01-2010 04:46 AM
Methods for cleaning/lubricating bearings? Chris__RC Nitro Off-Road 37 04-24-2009 08:35 PM
