Remove battery tray in M11 >
Old 05-18-2009, 09:41 PM
Default Remove battery tray in M11
How to remove it? thanks.
ioxqq is offline
Old 05-18-2009, 09:46 PM
Francis M.'s Avatar
You have to remove the batteries so you can then pull the tray out of the case......
Francis M. is offline
Old 05-18-2009, 09:51 PM
Thanks but it still not able to pull out. Looks like I need to open the radio case to remove the tray but I want to confirm.
BTW, I own 3PK, EX10, they are easy to remove the tray but this M11 seems like is locked in the case.
ioxqq is offline
Old 04-27-2012, 08:50 AM
Trader Rating: 23 (100%+)
Hate to revive a 3yr old thread, but having the same problem and can't find any info anywhere. Want to install a 3s but can't get tray out. Any help would be appreciated. Thanks.
msave is offline
Old 05-31-2012, 09:56 PM
I'm in the same boat here msave... Have you found any more info or had any luck with removing the battery tray?
lapu2 is offline
Old 06-01-2012, 04:36 AM
wingracer's Avatar
Trader Rating: 24 (100%+)
It's a VERY tight fit. Just keep yanking on it, it will come out.
wingracer is offline
