Old 05-17-2009, 05:59 AM   #1
Jamesalex's Avatar
Questions?? Bodyshell cutting
I am getting some new shells and I was wondering how everyone cuts out the wheel arches as I always seem to have trouble cutting them out?
Tips and tricks would be a great help
cheers
Jamesalex is offline   Reply With Quote
Old 05-17-2009, 06:22 AM   #2
panda racer's Avatar
Here's what I do:
If the wheel arches are marked:
I use rounded scissors for the first cut and then sand down the rough parts (if any) with 600 grit paper until the surface finishing is perfectly smooth.
If there are no markings for wheel arches:
I place the body shell on the car, using the front wheels as a reference, then I drill holes for the body posts, and I mark the wheel axle's position on the body.
After that I attach a X Acto knife to a compass and I use it to trace the wheel markings, using the wheel's axle position and the tyre's max diameter + 2mm to draw the circle.
Once all this is done I carry on with the first part.
HTH
Any car which holds together for a whole race is too heavy.
Colin Chapman
panda racer is offline   Reply With Quote
Old 05-17-2009, 09:54 AM   #3
niznai's Avatar
Originally Posted by panda racer View Post
Here's what I do:
HTH
Using the factory marked wheel wells doesn't guarantee the body will fit on the wheels properly, so I always first do a fit and eyeball where I would think the wheels would sit best, drill the bodypost holes and then follow on from there as explained above in the second paragraph. I use an Olfa compass. I then try fit the body and enlarge the wheel wells until I am satisfied the body won't catch in the wheels especially the front at full lock either way. I use for this operation a sanding drum on a drill press, so edges end up smooth as silk.
Tamiya bodyshells are very good quality in this respect and normally you can cut straight away as per their markings, but when using a non-Tamiya chassis it is worth a check especially for the body posts.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-17-2009, 01:11 PM   #4
Regional Moderator
CarbonJoe's Avatar
Ream out body post holes, cut lower portion of body to desired height, mount body on car (with correct wheels on it). I then use a circle template (like a draftsman would use) to mark the desired diameter centered over the axle. You can then either cut the wheel arches out or wait until after painting. I've seen some guys glue sandpaper on an old wheel and chuck that in a dremel to sand the wheel arches. I always round the sharp points (where the circle you cut intersects the lower edge of the body) with scissors, so that they don't slice your tire when you hit something.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 05-17-2009, 01:24 PM   #5
freeway's Avatar
for wheel arches i use a Ofna circle cutter on HPI shells. other shells with no center indent i scour it with my cutter (Ofna) then tear away, just be real carefull scouring as the blade gets offline. i then finish with dremel sander to even it out.
freeway is offline   Reply With Quote
Old 05-17-2009, 01:53 PM   #6
Foxxrocket's Avatar
I use this.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
MNC GP 2009 Rd2, Titiwangsa Track 12th April 2009 bgdesmoulin Malaysian R/C Racers 115 04-15-2009 09:39 AM
Malaysian National Championship (MNC) 2008 KoE Malaysian R/C Racers 769 01-04-2009 09:35 PM
FEMCA 1/10th and 1/8th Onroad Championship Danny Teh Malaysian R/C Racers 152 09-07-2008 09:49 PM
Holes on the body front and rear wind screen xscape Singapore R/C Racers 16 01-31-2007 05:34 AM
