Old 05-17-2009, 02:42 AM   #1
bydand53's Avatar
Default HB Cyclone TC - CV Drive Shafts
I'm having a problem with the purple aluminium CV drive shafts on the front of my Cyclone TC.
In the last 2 meets I have stripped the head of one shaft and snapped another clean through at the groove.
Does anybody know of an after-market alternative or am I doing something wrong ???
Richard
bydand53 is offline   Reply With Quote
Old 05-17-2009, 04:34 AM   #2
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Richard
running mod with a spool? i think its fairly common for that to happen. we usually replace it with the steel version and just keep the aluminum shafts for the rear.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 05-17-2009, 04:36 AM   #3
shadow102's Avatar
Trader Rating: 21 (96%+)
They don't like to take hard hits up front I have gone through several sets for that reason. Best solution is I still run the purple shafts out back but I run the heavy duty cyclone steel universals up front (the black non cvd type) I ran them for most of the winter season with no problem.
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 05-18-2009, 06:34 AM   #4
bydand53's Avatar
So should I run a locker or a one-way up front ?
Old 05-18-2009, 11:16 AM   #5
SammyZ's Avatar
Trader Rating: 138 (100%+)
+1
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 05-19-2009, 05:44 AM   #6
shadow102's Avatar
Depends on your track and what you feel Is better for you. Personally one way diff's aren't something seen much if at all any more as the spool is suited for a larger array of track layouts and surfaces
www.nexusracing.com
www.go-rc.org
Tamiya TB-Evolution IV gtypecanare Electric On-Road 3600 11-03-2017 01:06 PM
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 11:42 PM
