Old 05-17-2009, 12:18 AM   #1
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
Default anyone know where to find these gears for shaft driven touring car?
hi guys,
i'm just looking around for these gears..no i'm not trying to replace gears on my car... but since this is a big forum, maybe someone might know where to get these. if anyone can help me find these, i'd be very appreciative! gears are 1:10 touring car.
im looking for a 18t and 13t input gear
and a 42t and a 39t (found) diff gear
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 05-17-2009, 01:07 AM   #2
39t gear found
but i am still open for suggestions! would be awsome if i could find these gears together (like 18 & 39, 13 & 42 etc etc)
-valentin
www.csjunkies.com
Old 05-17-2009, 02:29 AM   #3
Hyde's Avatar
Can you let us know for what make and model of car??
Tc4? There's a bunch of shaft drivin cars what should we be looking for
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 05-17-2009, 04:07 AM   #4
Those look like gears from a Tamiya Evolution series shaft drive car.
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 05-17-2009, 11:32 AM   #5
all of these gears are off different shaft driven cars. i'm trying to mod the drivetrain so the front is underdriven and the rear is overdriven (drifting thing)
so i'm not really going for "certain make" but im trying to go for number of teeth and ratios
-valentin
www.csjunkies.com
Old 05-17-2009, 10:46 PM   #6
bumperoo come on guys =D
-valentin
www.csjunkies.com
Old 05-17-2009, 10:52 PM   #7
pakk's Avatar
Trader Rating: 79 (100%+)
You are one serious drifter my friend, I like it.
I did not even know this was an option. If it is, I would like to change the internal ratio of my TC4. Are different gears available?
--pakk
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 05-17-2009, 10:56 PM   #8
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
hi guys,
Bottom right gear looks like it's from a Duratrax Vendetta.
JamesArluck is offline   Reply With Quote
Old 05-18-2009, 12:02 AM   #9
niznai's Avatar
Yokomo SD cars use a 40/17 crown/pinion setup.
Your idea might work but I have experienced a problem with this sort of idea. I have used Losi pulleys on my touring car to overdrive the front (41 front/42 rear) and the end result was that the diff balls enlarged their holes and eventually the pulley became useless because the plastic flared out and rubbed on the diff plates.
I think you should go for a minimum overdrive/underdrive ratio (one tooth difference on the crown). One tooth difference on the pinion is too much. If you already found the 39 tooth crown this would be a good first test to do, using the Yok pinion/crown on the front and the 39 crown with a Yok pinion on the rear. Thsi will give you a ratio of 2.2941 rear to 2.3529 front.
But all this is somewhat academic since in drifting you want to break loose so fdr doesn't mean much anyway.
Even so, you might encounter gear mesh problems because I am not sure the pitch is the same on all these gears.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-18-2009, 07:25 PM   #10
--pakk
yes there are different gears that can be used, but not specifically made for tc4. you have to use gears from different chassis
that small 1 tooth change will not be enough to accomplish what i need the gears for. the gears are actually for some friends of mine that run shaft driven cars, and well, the problem you brought up should not be a problem due to the fact that these cars will be running spools in the rear and oneways up front. the purpose of these gears are to allow the car to have more over-steer, and to allow not only MORE counter steer, but to allow counter to be held. thus making the drifting much much more realistic.
see here for what i mean by "counter-steer" drifting
http://www.youtube.com/watch?v=czuBpcuOa8o
as for FDR, FDR is and can be pretty crucial to drifting also, the FDR of the car greatly influences how the car reacts when it is going sideways, and drift initiation. we aren't just random bashers that throw whatever into our cars
-valentin
www.csjunkies.com
Old 05-18-2009, 09:34 PM   #11
niznai's Avatar
Granted I don't know much about drifting. It would be interesting to see the results of your experiment. Are the guys in the video you linked running a setup similar to what you want to build?
Team Greasy Weasel
Old 05-19-2009, 12:29 AM   #12
well, i wont be building a countersteer car soon...i'm searching this stuff for a friend of mine. the car(s) in the video are a bunch of my fellow drifters that have already built their countersteer cars, but with belt driven. belt is more popular for the simplicity of swapping pulleys. there are a few with shaft driven overdrive, but im sure more will try it if i can find these gears so they dont have to spend the $50 (some guy on another forum is trying to sell these specific gears for $50!!)
-valentin
www.csjunkies.com
Old 05-19-2009, 12:47 AM   #13
niznai's Avatar
There are companies on the web who sell gearboxes like that and I suppose they have various gear ratios to play with. The guy from Romania with the newly built car (Hyro) has bought his gearboxes off a company like this. Perhaps you can get in touch with him and find out.
But I thought all drift cars were drifting like that (counter steer is known as opposite lock downunder) without any need for a special overdrive/underdrive drivetrain. There's a great drift club here in Adelaide with their own website and track and you can find their youtube videos and see. Hobby Habbit is the shop name. Look it up.
http://www.youtube.com/watch?v=Z3PXcpsbCyo
Team Greasy Weasel
Old 05-20-2009, 09:20 AM   #14
hmm, maybe ill look into that gearbox company. we'll see
yes, drift cars do counter like that, but the counter isnt held, so it doesnt look like the real thing. sometimes, r/cs are forced to turn INTO the corner mid drift, when have you seen that on a 1:1?
-valentin
www.csjunkies.com
Old 05-20-2009, 10:39 AM   #15
niznai's Avatar
I have noticed that indeed, but am not sure the only way to drift with opposite lock is overdriving the front. Real cars (since you mentioned them) don't need it, so there must be another way. I suppose more power and/or a bias in the front to rear grip could help.
Team Greasy Weasel
