Old 05-12-2009, 09:30 PM   #1
Default tc4 steering
I picked up a tc4 off of eBay and am having some trouble with the steering setup. The car will consistently pull to one side, but it will pull both to the left and right. The steering servo doesn't seem to recenter. You have to counter steer to correct the pull even on a straight. There's little slop in the linkage, and the serve seems to be working fine. I also increased the toe in on the fron tto try to make it more stable. Any ideas?
nitro20 is offline   Reply With Quote
Old 05-12-2009, 09:33 PM   #2
revo523's Avatar
either something is binding in your suspension or your servo is bad and it don't center itself.
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
revo523 is offline   Reply With Quote
Old 05-12-2009, 09:40 PM   #3
I pulled the linkage off the servo, and it moves freely. The strange thing is that if you look at it on a table and steer, it appears to recenter. The steering problem is really noticable if you gun it and have to counter steer.
Old 05-12-2009, 09:44 PM   #4
revo523's Avatar
What servo is it? Spec's?
Spektrum DX3S
Old 05-12-2009, 09:48 PM   #5
Hitec HS525MG
Old 05-12-2009, 09:53 PM   #6
revo523's Avatar
Have you checked your camber, toe?
Spektrum DX3S
Old 05-12-2009, 09:56 PM   #7
TomTomTuning's Avatar
Trader Rating: 19 (100%+)
Does it pull to one side after you turn to that one side..
Like its not centering correctly?
I had this problem when i installed my new caster blocks. I Installed the block carrier bushings incorrectly, so the steering was tight.
Here is the TC4 Manual, in case your not sure where they belong and how to install them correctly.
TomTomTuning is offline   Reply With Quote
Old 05-12-2009, 10:03 PM   #8
I set additional toe in to try to make it more stable, and camber is set to 1 deg all around.
Old 05-12-2009, 10:07 PM   #9
I'll have to check the caster blocks and bushings. I never got that far. It wouldn't surprise me to find out something wasn't installed properly. I've been fixing a sloppy build since I got this thing.
Old 05-12-2009, 10:09 PM   #10
Yea.. Its easy to put them in wrong.. The lip needs to be inside and touching the steering hubblock..
Old 05-13-2009, 12:04 AM   #11
philly123's Avatar
Trader Rating: 17 (100%+)
Agreed... make sure the caster blocks are on the correct side and the bushings are inserted correctly, also unhook the servo and move the wheels left to right to see if it is loose or tight. If it is tight then there is something binding, if it is free then my guess would be that it is your servo. Goodluck, the TC4 is a durable car.
--Brownies Pro and Sport Hobbies--
--Majs RC--
Team 3-Quarter
philly123 is offline   Reply With Quote
Old 05-13-2009, 08:08 AM   #12
Yea, good idea.. That should belp narrow it down quicker.
I love my TC4. If you ever go bushless... I recommend steel outdrives and the heavy duty CVD's!!!
Old 05-13-2009, 08:12 AM   #13
A car with negative caster (king pin line tilting forward) will be hard to keep on a straight line -- if not impossible.
If the caster blocks are flopped left to right, you could have a negative setting.
If the caster is ok (positive), your problem is likely the servo.
jhberger is offline   Reply With Quote
Old 05-13-2009, 08:14 AM   #14
I'm actually looking at an LRP Sphere Competition esc right now with 2 orion motors. This will be my first brushless setup that isn't a Mamba Max. First things first though, I've gotta get this thing to track straight first!
Old 05-14-2009, 11:39 AM   #15
heretic's Avatar
Hitec HS525MG
seriously you answered your own question there. Buy a 8$ futaba and the problem will surely disappear.
heretic is offline   Reply With Quote
Team Associated TC4 Kenshin Electric On-Road 15368 Yesterday 09:23 AM
TC3 Forum Lowrider Electric On-Road 12196 10-13-2017 09:47 PM
TC4 Team car 4 sale 150 shipped 48 conus revo61 R/C Items: For Sale/Trade 82 06-24-2007 12:45 PM
Shaft Vs. Belt drive Little_Mike Electric On-Road 57 06-14-2007 01:31 PM
RDX with dura arms and parts olhipster1 R/C Items: For Sale/Trade 11 12-17-2006 07:45 PM
