futaba 3PK synthesizer >
Old 12-18-2003, 07:29 PM
  #16
Hey guys thanks for the info, but now for those of you that aren't running a hitec module and novak receiver, what are you doing for freq. changes? are you actually buying new modules and a receiver crystal or is there another way?
tricklosi is offline
Old 12-18-2003, 09:36 PM
  #17
RC Scoring Pro's Avatar
Just changing the crystal in the module, don't need more than 1 module.
RC Scoring Pro is offline
Old 12-18-2003, 10:21 PM
  #18
robk's Avatar
Trader Rating: 22 (100%+)
It was stated to me by a Novak engineer at the hobby show in Chicago that the Novak receivers (XXL and Synthesized) will work with HRS systems of all types (Futaba Ko etc) as thier receivers already run at a faster processing rate than the OEM HRS stuff.
This has also been proven at the track by several guys who have tried it out with various systems.
As far as the modules, i didn't ask about that.
robk is offline
Old 12-18-2003, 10:26 PM
  #19
So i have to dis-assemable the module to get to it? mine doesn't look like it's acessable from outside the module????
Old 12-19-2003, 01:07 AM
  #20
jfischer's Avatar
I have the 3PK and a few XXTRA and a true Futaba HRS receiver. With the Spectrum module in the radio it works fine with the XXTRA and most servos, but when you put the HRS receiver and a digital servo together you will get all kinds of glitches in the servo, so you HAVE to have a standard module in the radio for HRS. Sad to see, and I was in hopes that Novak was coming out with a module that would work in the Futaba radios, but from what I have seen they are saying that is not going to be now. Have any others seen anything different or heard anything from a GOOD source.
jfischer is offline
Old 12-19-2003, 03:10 AM
  #21
I've been using my 3PK with HRS and Spectrum module and hs5945mg & hs5625mg with no problems and no glitches for 3 months now.
candy man is offline
Old 12-19-2003, 04:47 AM
  #22
Rick Worth's Avatar
Just take the module out of the radio & there is probably (in 1 corner) a small black aluminum cover that is stuck on the module. Pop it off with an Exacto knife to reveil the crystal. Leave the little plate off so you can change the crystal whenever needed.
Rick Worth is offline
Old 12-19-2003, 08:01 AM
  #23
Cool, thanks i'll give it a try....
Old 12-19-2003, 12:07 PM
  #24
Im pretty sure removing or switching out the crystal voids your warrenty.
AE Racer is offline
Old 12-19-2003, 12:11 PM
  #25
rc-zombies's Avatar
no..I don't think it will void warrantee... I switch crystals all the time. I've got a complete set of 27mhz FM for my 3PK so I don't have any frequency conflicts at the track. Hope the synthisizer module and receiver comes out soon...so I can get rid of my crystals all together.
rc-zombies is offline
Old 12-19-2003, 12:19 PM
  #26
Where did you get 27mhz crystals for the 3PK ? I know some guys at the track have some weird crystals (maybe from Japan) that are on unique frequencies.
Old 12-19-2003, 12:26 PM
  #27
rc-zombies's Avatar
You can order them from HK or Japan.
I've got both US and overseas channels.
the overseas channels are available as well that fall inbetween the US channels (A#)...
Here's the complete list of 26mhz channels available:
RC01 26.975
RC02 26.995 A1 BROWN
RC03 27.025
RC04 27.045 A2 RED
RC05 27.075
RC06 27.095 A3 ORANGE
RC07 27.125
RC08 27.145 A4 YELLOW
RC09 27.175
RC10 27.195 A5 GREEN
RC11 27.225
RC12 27.255 A6 BLUE
it's nice having the non US channels at the track... No other racer will have it...so no conflicts...
Old 12-19-2003, 02:15 PM
  #28
ilaybrk's Avatar
I have a set of crystals but are on 27.315 and cant find on any chart
ilaybrk is offline
