Old 05-06-2009, 02:26 AM   #1
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
Default ESC and Motor Timing Combo's 17.5
Hello,
Im currently running an LRP Sphere TC Spec and recently picked up a Trinity Duo 17.5 which has adjustable timing. Just wanting to know what would be the best way to run timing? through the motor or esc or a combination of both? what seems to be the best settings for 17.5? what will more or less timing do? give me more torque/ RPM? Sorry im new to all this timing stuff.
Cheers
Fast XXXS is offline   Reply With Quote
Old 05-06-2009, 06:37 AM   #2
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Try profile 8 on the TC spec. Check temps then try dropping a tooth on your pinion and advance the timing a bit. With a 17.5 you will probably end up with quite a bit of timing. Just be careful with the temps. Increasing timing either by speedo or motor will run hotter.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 05-06-2009, 04:41 PM   #3
Fast XXXS's Avatar
Thanks for that Pablo, my esc is already on 8 . So from what i gather if you increase timing you will get more RPM/ Top end but if you reduce the timing you will have more torque/ acceleration? And by dropping down teeth in the pinions that compensates for the reduce of torque when increasing timing?
Old 05-06-2009, 06:28 PM   #4
You also have to drop teeth to keep temps under control. More timimg also means more heat. Try different timing/gearing combos and hopefully you will find a sweet spot.
Paul H
Old 05-07-2009, 08:41 AM   #5
decibels's Avatar
Hello,
Cheers
If what i know is correct then timing on the can itself will only take affect upon initial take off and after that the timing is completely controlled by the speedy!!
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 05-11-2009, 03:29 PM   #6
Mr RCTech's Avatar
I run ZERO degree of motor timing on the can and run higher throttle tomming on the speedo.
I find it gives me more lower-end torque (punch) off the start without heavy
battery loads with higher motor timing.
More throttle speedo advances the tomming for max top-speed.
I find that this works better for me. And now you know...
Mr RCTech is offline   Reply With Quote
Old 05-11-2009, 11:14 PM   #7
Fast XXXS's Avatar
Thanks for the info. Im wanting to get the most torque out of my motor but not sacrafice to much top speed, will running the motor with zero timing or the esc with the least timing be better for torque?
Old 05-12-2009, 07:02 AM   #8
rcterp's Avatar
Trader Rating: 35 (100%+)
Keep the motor at 0 (which is not really 0 anyway) and using the timing on the ESC. Gear down a couple teeth.
This will give you torque off the line and out of corners and top end down the straight.
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 05-12-2009, 09:11 AM   #9
Move your timing on your motor up 2 degrees at a time, run it for a few minutes and adjust again, until you find your desired torque and top end. then play with the speedo to smooth everything out.
AE BT is offline   Reply With Quote
Old 05-13-2009, 05:27 PM   #10
Fast XXXS's Avatar
Thanks for that. I can only adjust my motor 10degrees at a time, but ill give it a go. Any other opinions welcome! Just want to hear what seems to be the best way.
Cheers
Tamiya Championship Series Neil Rabara Racing Forum 21231 Yesterday 02:16 PM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
tekin or speedpassion bigemike Electric On-Road 23 11-05-2008 11:55 AM
Novak Pro Racing Brushless Systems Drift_Buggy Electric On-Road 13 02-10-2007 11:50 AM
