Old 05-05-2009, 07:16 PM   #1
lightfoot's Avatar
Default HPI Super F1
I realize this is an old chassis and no one is using it.... but someone out there knows the answer to this question...
I've adjusted the shock so that my ground clearance is even from front to back... unfortunately my ride height is 7 mm... I would like 5 mm ... my rear shaft bearing setting is set for lowest right height...
How do I lower the front and rear ? I do have a new set of tires on and I haven't trued them down... Is this the reason ?
Thanks for any input....
lightfoot is offline   Reply With Quote
Old 05-05-2009, 08:33 PM   #2
Hyde's Avatar
if its 7mm at the lowest setting that's maybe the lowest it goes. trueing the tires will knock off that extra 2mm. haven't heard of this kit lol
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 05-05-2009, 09:30 PM   #3
lightfoot's Avatar
It's the first kit HPI came out with... But There must be a way of lowering the chassis more besides truing the tires ????
Old 05-05-2009, 09:51 PM   #4
Manny's Avatar
Are you sure that you have the lowest bearing holder that associated makes? I have a Super F1 kit but I don't remember what bearing holders HPI included with them. I could be wrong, but they may not have included a complete set. You might want to try the IRS bearing holders they may lower the car a bit more but probably not an extra 2mm if you indeed have the lowest bearing holder available.
Manny is offline   Reply With Quote
Old 05-05-2009, 10:58 PM   #5
lightfoot's Avatar
Associated ? Not HPI ? I'm not sure... I bought the car used and assembled... but the bearing holder puts the bearing near the top of the motor mount... I assumed there might be three bearing holders... top , middle and bottom... maybe there is a "more top" holder ??? do you remember your Super F1 sitting kinda high ?
I just found the Manual on-line and the kit only came with two bearing holders... so maybe this is the way it's supposed to be...
http://www.hpiracing.com/instructions/instruct-f1.htm
Old 05-06-2009, 12:15 AM   #6
robk's Avatar
Trader Rating: 22 (100%+)
Buy a set of IRS #IRS1167 Ride Height Adjusters. They will get you as low as you can go. They offer more adjustment than the Associated parts, which I think HPI put in the kit as OEM parts.
Old 05-06-2009, 12:29 AM   #7
lightfoot's Avatar
Thank you very much... I just ordered the set... comes with 8 adjustments... now I still have the issue with lowering the front end.... what's the best way ?
Old 05-06-2009, 04:12 AM   #8
The only way I can remember to adjust the front ride height is to change the spacers on the king pin.
Old 05-06-2009, 04:44 AM   #9
Frank McKinney's Avatar
That's pretty much what I remember, I think there are plastic spacers that fit on the kingpin.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 05-06-2009, 08:04 AM   #10
robk's Avatar
You have 2 options:
Change the spacers around, as the other guys said. If that is not enough, you can get longer kingpins from rc4less.com or other oval pan car sites. Then you can add more spacers or washers to drop the front end.
You can also run the spring on the kingpin itself and lock the lower arm down by taking the spring and the A009 joint pin out of the arm. Put a screw and nut in the hole to lock the arm. You can also put spacers inbetween the arm and the mount to raise the lower arm, which will bring the car down.
Old 05-06-2009, 08:19 AM   #11
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
I have a NIB Super F1 on ebay right now....
user ID is "treasure-chest-traders"
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 05-06-2009, 09:26 PM   #12
lightfoot's Avatar
You have 2 options:
Your the Man ! I will give it a shot soon when my rear bearing holders get in....
Old 05-09-2009, 11:06 PM   #13
lightfoot's Avatar
Default Broke Front Arm
Broke my front arm today whats worse then just breaking a plastic part, is breaking a plastic part NOBODY has ... does anyone have HPI Super F1 parts they want to sell ? Especially front arms ....
Old 05-10-2009, 12:09 AM   #14
Manny's Avatar
Ouch! If you can't find the arms, Tamiya F103 arms will fit but you may have to switch to f103 wheels (unless someone knows of a way to fit the Super F1 uprights on the F103 suspension arms). At least you'll still be able to run the car.
Old 05-10-2009, 12:16 AM   #15
robk's Avatar
Ream out the Tamiya parts to take a 1/8 hinge pin, and run the HPI steering knuckle.
HPI's new F1 PhatPat Electric On-Road 1173 10-10-2013 12:18 AM
Wa Onroad Racing sleek the elite Australian Racing 8920 02-07-2012 09:52 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 01:52 PM
The New F206F1 From MLP Motorsports Marty Peterson Electric On-Road 368 01-12-2007 03:44 PM
Tamiya F201 F1 revzalot Electric On-Road 21 06-15-2004 08:30 PM
Electronics Sale RiceBurner923 R/C Items: For Sale/Trade 19 04-24-2004 01:30 PM
