Old 11-10-2009, 11:49 AM   #31
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Hey guys I have a few sets of the White Springs(soft) for the rear pod pivot system. If anyone is looking for them or is looking for more rear traction.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 11-10-2009, 12:50 PM   #32
marcel p's Avatar
Send a message via MSN to marcel p
wil rims of other brands fit the hpi .
somthing with foam like the tamiyas.
and how wil it hold in competition against the other f 1 cars.
like the f 104.
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 11-10-2009, 12:53 PM   #33
marcel p's Avatar
like the f 104.
sorry i ment this question about the new hpi formula 10
PR racing
Absima /vr racing
Old 12-03-2009, 07:23 PM   #34
lightfoot's Avatar
Default WCRC F1 racing
Looks like we have a regular F1 race schedule at WCRC...
3rd Sunday of every month, starting with December 27th 2009
Check site for more details....
http://www.charleslightfoot.com/WCRC_F1.html
Love and Peace...
Last edited by lightfoot; 12-09-2009 at 10:35 AM. Reason: date of event changed from 4th to 3rd Sunday
lightfoot is offline   Reply With Quote
Old 12-28-2011, 09:07 AM   #35
Conrad's Avatar
Bit of a thread revival but does anyone know if regular 1/10th pan car wheels or wgt spec wheel/tires fit the Hpi Super F1? I'm asking just encase their is any offset built in to the wheels.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 12-28-2011, 09:10 AM   #36
robk's Avatar
Trader Rating: 22 (100%+)
pan car wheels fit fine
Old 12-28-2011, 09:24 AM   #37
Conrad's Avatar
Thank you kindly Sir Don't suppose you could recommend a good starting point for tire compounds running on carpet without additive?
Blue front, green rears with plenty of additive on the rear was par for the course when I used to race it every week back in the day but as ever tire compounds have moved on alot since then.
Old 05-17-2013, 10:17 PM   #38
Default wheel adapters
so does anyone know if there are any adapters to put the tamiya f1 rubber tires on a hpi super f1
okracer is offline   Reply With Quote
Old 05-17-2013, 10:38 PM   #39
Here is how we used to do it...we always used the old tape trick to hold the metric bearings in the standard sized holes. You'll need a whole Tamiya rear axle assembly, 5mm ID rear bearings that are just a lil smaller in OD than the stock 1/4"x3/8" bearing and with the F103 wheel the front bearings should be fine. Put a piece of tape over the rear bearing hole and cut a + in it, then press the metric bearing into place, the tape will make up the size difference from the standard to the metric. Then you can slide the rear axle assembly into place and shim as needed to get the width correct. For the front wheels you do the same thing...place a piece of tape over the bearing hole in the rim and cut a + into it, then press the bearings into place and shim as needed. It's not a great solution but it does work.
I believe the Top F1 car uses standard rear bearings and maybe a metric front axle with a knuckle for a standard king pin. So it may be possible to convert to Tamiya rims using the Top F1 rear axle assembly and front steering knuckles and axles.
I'm not sure its all worth it though...for the cost to do all of that your already half way to a new F1 car that you won't have to fuss with to make work with the rims.
Old 05-18-2013, 11:04 PM   #40
eff one's Avatar
If you can find the hpi f10 rear diff for foam package, hard to find and pricey, it will mount perfectly just shim for center and width. The part was listed on the hpi web site under f10 parts. 103 rims slide right on..
BLASTF1 Championship
Racing since 1994
eff one is offline   Reply With Quote
HPI's new F1 PhatPat Electric On-Road 1173 10-10-2013 12:18 AM
Wa Onroad Racing sleek the elite Australian Racing 8920 02-07-2012 09:52 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 01:52 PM
The New F206F1 From MLP Motorsports Marty Peterson Electric On-Road 368 01-12-2007 03:44 PM
Tamiya F201 F1 revzalot Electric On-Road 21 06-15-2004 08:30 PM
Electronics Sale RiceBurner923 R/C Items: For Sale/Trade 19 04-24-2004 01:30 PM
