tire inserts
Old 12-15-2003, 02:16 PM
hierog's Avatar
Default tire inserts
can somebody tell me what I can expect by putting different tire inserts into the same tire, ie firm insert vs soft insert into Sorex 24's? i'm going to race on carpet for the first time this weekend and I only have Sorex 36's w/ medium inserts and Sorex 28's. i normally race at Speedworld during the spring, summer months, so i'm in need of picking up some new tires
thanks
vic
hierog is offline
Old 12-15-2003, 04:38 PM
hierog's Avatar
come on, somebody's got to know!!
hierog is offline
Old 12-15-2003, 05:49 PM
Joel Lagace's Avatar
I run on carpet.
Sorex:
Front 24 with blue hpi insert(hard)
Rear 24 with green hpi insert(med)
I think what happens is a harder insert is better for the front since alot of load occurs up front just as why we run plaid or ring compounds in foam fronts its to keep the tire from rollng.
I feel that it would take away a small amount of traction so that your not hooking. I find that this combo works well but have had traction rolls near the end of a race day. things tend to warm up as the day goes on and i need to lay off the tire juice.
Hope this helps.
Other guys are running 28s all around at our track. But currently i have TQ'd and one most of my races with this set up this sereis. Could be the yoko SD or the SMC cells though
Joel Lagace is offline
Old 12-15-2003, 07:34 PM
P2
P2's Avatar
Trader Rating: 15 (100%+)
Are you racing at STRC in Stockton?? If so try 28s up front and 24s in the rear with HPI red inserts. Also go to www.rcracing.com message board. Most of those guys post on that site.
P2
P2 is offline
Old 12-15-2003, 07:45 PM
JoshR 85's Avatar
HeY!!!
Hey lately i've been running the Takeoffs (27's) they're just as good as sorex i think, maybe like .1-.3 tents of a sec. slower but yeah.
JoshR 85 is offline
Old 12-15-2003, 08:18 PM
Take offs last longer, and no doubt look great after a few runs. Where Sorex come off looking scary after just one or two runs. But hands down SOREX offers more grip then the takeoffs.
The BS tirewar with rubber is what got me so hell bent on running foams on Sedans both nitro and electric. I remember attending events where guys where running there rubber tires for one run and then cutting them open to re-use the inserts in a new set of tires!!! Sorry not fun. I can now run foams from new to the rim with great grip the whole time.
I went form spending $1000s on rubber trying to find the golden tire to just buying 2 sets of foams for 20 race sereis+++(no way you could make rubber go that far.)
Old 12-15-2003, 08:37 PM
STLNLST's Avatar
Trader Rating: 31 (100%+)
DON'T mount up any sorex tire's with hpi blue's if you're racing in stockton. If you can't get a set of 28/24 with hpi reds or 28/24 with sorex firm A's then go with the take off 27's. I plan on racing this weekend so I'll just give you a set of take off's. I have a ton of them. You know who I am so just come and find me on Saturday.....better yet if you plan on going to speedworld at all this week I'll bring them by the shop. Let me know what you want me to do.
STLNLST is offline
Old 12-15-2003, 10:12 PM
JoshR 85's Avatar
HeY hEy!!!
Joel actually foams u have to cut them down though every amount of runs and that, and chunk if u catch a corner and the takeoffs they lasted me quite awhile w/ really good performance.
JoshR 85 is offline
Old 12-15-2003, 11:06 PM
fatdoggy's Avatar
Truing - Takes all of 40 seconds and if you rotate them each run it won't take much.
Chunking - Easy to fix, silicon or shoe goo works great in the hole, traction really isn't that effected if it's not a big chunk.
fatdoggy is offline
Old 12-16-2003, 06:56 AM
hierog's Avatar
STLNLST,
yeah, i plan on running in stockton this weekend. I'll be by speedworld on Friday about 1-2 pm
thanks
vic
hierog is offline
Old 12-16-2003, 08:01 AM
STLNLST's Avatar
STLNLST,
thanks
vic
I'll drop the tire's off to Billy on wednesday with your name on them and I'll see you on Saturday.
STLNLST is offline
Old 12-17-2003, 06:51 AM
hierog's Avatar
thanks!! - see you sat!
vic
hierog is offline
Old 12-18-2003, 08:20 AM
TC3
TC3's Avatar
sorex 28's with orion JB blue inserts is the way to go...
on low grip track u need sorex 24's...
TC3 is offline
Old 12-18-2003, 08:03 PM
STLNLST's Avatar
vic
I dropped off 4 sets of tire's for you. If you need more just let me know. I still have more.
STLNLST is offline
Old 12-18-2003, 08:54 PM
hierog's Avatar
sweet - thanks again!
hierog is offline
