tc5 10.5 gearing help
i am running a 10.5 at 34/74. any one comment on this please
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
That's a 5.44 final drive...what exactly do you need to know?
How do you know with out knowing his internal ratio? Or is d2 a car? Maybe he wants to know if that is a good FDR for that turn motor. If so, you are in the ball park.
--pakk
--pakk
if your running a 74 spu / 34 pinion . your FDR is 4.53 ,,
if you can check here www.gearchart.com . remember FDR will change depending on track ( asphalt / carpet ) layout ..
also running a 10.5 about 5.0 final should do just fine ..
I ran my 10.5's at around 5.2-5.3, but it really depends on the size of the track.
what if i run that gearing with a 13.5? 34/74 i guess that what i am trying to get at is is this too much for a 13.5? i see that it will be for a 10.5 so that is out
