Old 05-01-2009, 11:31 PM   #1
B4
B4's Avatar
Default Cogging
I have the following LRP Spere Esc & Orion 17.5T BL.
Everything was fine and when I went to go out for the next race the car would not move. I pulled the shell off and if i hold the controller above neutral the motor will not move, however if i start to rotate the spur it's ok but only under no load.
I can can take the motor to top speed and nearly back to zero without a problem holding the car up. What I can't do is hold it just above neutral because it does what I would call cogging. I have tried setting up my ESC again.
Can someone with more experience tell me if they think it's the ESC or motor.
Thank you
B4 is offline   Reply With Quote
Old 05-02-2009, 12:17 AM   #2
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
We have had similar problems with the Quark and LRP ESC's. It does have a bit to do with the gearing as it is quite low with 17.5 motors. With the speed passion motor we re shimmed the rotor so the rotor sits closer to the sensors. This helped with the cogging a fair bit. Im not sure about the Orion motor, could be a similar problem to the SP motor so might be worth a shot.
mild seven is offline   Reply With Quote
Old 05-02-2009, 03:54 AM   #3
B4
B4's Avatar
Thanks Ill give that a try.
Old 05-02-2009, 06:13 AM   #4
rockstar81's Avatar
Any possibility it is a bad sensor wire? I have had a few go bad before with similiar results.
Dee & Mee Hobbies, Team Academy SBV2, Xray 009, Xray 007, Castle Creations, Spektrum DX3R, Ricky Racer Customz, Tekin, Thunder Power, Duratrax Onyx,
rockstar81 is offline   Reply With Quote
Old 05-02-2009, 07:41 AM   #5
Trips's Avatar
Trader Rating: 16 (100%+)
I have to agree with rockstar If everything was working fine and suddenly it won't start, that to me suggests a bad or unplugged sensor wire...
MARSHAL!!
Trips is offline   Reply With Quote
Old 05-02-2009, 09:26 AM   #6
Trader Rating: 17 (100%+)
I had a Novak SS speed control fail with those exact symptoms. Car will not move from a standstill, but give it a little push and it goes. Then at low speeds it was cogging badly. If I picked it up and gave it a bump it would seem normal. Novak replaced the ESC and told me it was a bad phase. Everything works fine now.
burnineyes is offline   Reply With Quote
Old 05-02-2009, 10:00 AM   #7
Hyde's Avatar
I had cogging with my mamba max and it turned out to be cheap cells. when your BL motor is starving for power it will cogg. when I get better cells the problem went away.
I could be wronge on what's happening with you
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 05-02-2009, 06:03 PM   #8
revo523's Avatar
I had the same problem with my lrp and it was the sensor wire.
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
revo523 is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14339 12-13-2017 11:20 PM
The Speed Passion Thread memix Electric On-Road 13377 11-28-2017 11:06 PM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Hobbywing ESC's Drift_Buggy Radio and Electronics 827 03-30-2016 11:43 PM
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 06:31 PM
Hot Bodies Cyclone D4 EP buggy Mike Schumacher Electric Off-Road 1921 10-06-2014 12:33 PM
Team Orion Vortex Brushless motor Aku-Man Electric On-Road 719 05-27-2011 03:46 PM
