Damaged LiPo?
Old 04-30-2009, 09:04 PM
Trader Rating: 25 (100%+)
Default Damaged LiPo?
Should i toss it? I smashed into it with my tc3, shatter the hardcase, and thats whats the inside looks like.
Attached Thumbnails Damaged LiPo?-dsc_0212-medium-.jpg   Damaged LiPo?-dsc_0213-medium-.jpg
agarabaghi is offline
Old 04-30-2009, 10:31 PM
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
It's toast...I googled proper lipo disposal and about everything I read indicated to cut the wires off close to the pack and soak it in a bucket of salt water for 2 weeks, then you can just toss it with the regular trash.
-rocky b
flatspunout is offline
Old 04-30-2009, 11:11 PM
mild seven's Avatar
Trader Rating: 63 (100%+)
Yep soak the pack in salt water. havnt heard about leaving it in for 2 weeks tho. seems like quite a long time
mild seven is offline
Old 05-01-2009, 04:16 AM
academygaz's Avatar
Sticking it in saltwater will break down the alu tabs that hold the pack together before the pack is discharged, so it will still has a lot of energy left in it.
The proper method is:
1. Discharge the pack to 0v on a low drain (like a fan, lightbuld etc).
2. Submerge in a salt bath for several days
3. Toss in the trash.
academygaz is offline
Old 05-01-2009, 04:54 AM
I was told to try and charge it and see if it bloats, if it does its toast?
Old 05-01-2009, 05:10 AM
RC TTwins's Avatar
Trader Rating: 43 (100%+)
if u do that just be careful not to burn down ur house that would be bad
RC TTwins is offline
Old 05-01-2009, 07:14 AM
According to Thunderpower, charging/discharging a damaged cell is a bad idea...here's the link:
http://thunderpowerrc.com/PDF/DISPOS...-BATTERIES.pdf
-rocky b
