7.2V servo/ESC hookup >
Old 05-24-2004, 11:02 PM
  #16
Originally posted by True R/C Racing
I just baught the 2123 and have a keyence..Yellow wire works fine?
My wire was green???j?k???
ZER01 is offline
Old 05-25-2004, 07:14 AM
  #17
Wency_TA03R-PRO's Avatar
Exclamation
Wency_TA03R-PRO is offline
Old 05-25-2004, 12:44 PM
  #18
So does the PDS-2123 Work good connecting it to the Yellow on Keyence zero extreme? How did you connect it since the yellow wire has not type of connector?
True R/C Racing is offline
Old 05-25-2004, 01:47 PM
  #19
fatdoggy's Avatar
Either solder it to connectors or just solder it together and shrinkwrap it. There is a loose wire coming out of the servo right? That's how I always assumed it was done.
fatdoggy is offline
Old 05-25-2004, 07:53 PM
  #20
I connected mine by soldering the very end of the blue wire(after the connector) to the yellow wire off the ESC with the KO supplied choke in between.
ZER01 is offline
Old 06-06-2004, 01:52 AM
  #21
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
okay i don't have the KO, but i do have Airtronics 94758Z digi servo. is there ANYTHING I HAVE TO DO to hook these up. this is my first time doing this.
JayBee is offline
Old 06-07-2004, 09:07 PM
  #22
Other than plugging it into the receiver, no. That servo is a 6.0V servo not a 7.2V.
ZER01 is offline
Old 06-07-2004, 09:57 PM
  #23
JayBee's Avatar
Post
Is the 7.2V servo better or is that like the maximum volt handling capacity rating
JayBee is offline
Old 06-07-2004, 10:13 PM
  #24
No the 7.2V rating means that it needs a minimum of 7.2V to operate which means the servo will be faster and have more torque. That is a .06 sec. servo.
ZER01 is offline
Old 06-07-2004, 10:21 PM
  #25
JayBee's Avatar
Post DAMN
I haven't done any research on that KO, but is this one better than the Airtr. unit and as far as servos go, how quick is too quick?
JayBee is offline
