Lame as hell Head-scratcher
Hi there, just had a thought...
Do any of the gears from an M-03 fit the TL-01 rear or front gear case? Thanks. |
Only the differential.
the main spur gear, and idler gear don't work. its all different ratios and different dementions
i actually want different ratios though. tis the thing.
Originally Posted by Dorigecko
(Post 5755026)
they don't work/fit. buy some tl01 gears off evil-bay, if you want different gear ratios then dremel the motor mounting holes to put bigger tamiya pinions sizes. this isn't a good idea tho if you want more gearing options buy a up to date car. but the tl01 stock is a perfect car STOCK |
