Old 04-26-2009, 05:44 AM   #1
Trader Rating: 31 (100%+)
Send a message via Skype™ to vstrok
Default New to On-road
I have been messing with electric off-road for a while. I want to get into on-road....for fun! Does any manufacturer make an RTR model with a brushless sytem?
Ofna GTP2e - Tekin RX8 / Tekin 2250 kv
Ofna Hyper 10SC - MM Pro / Castle 6900 kv
Ofna Hyper 10TT - MM Pro / Tekin SC4X 5.5T
vstrok is offline   Reply With Quote
Old 04-26-2009, 07:00 AM   #2
passinby's Avatar
hpi has the sprint 2 flux ,its the same brushless system as the sidewinder 5700 hpi just put there flux name on it im not a big fan of it,its ok for parkin lot bashin but not a racer but thats the only one that comes brushless that i can think of
passinby is offline   Reply With Quote
Old 04-26-2009, 07:24 AM   #3
Trader Rating: 36 (100%+)
YGPM
EVILGRAFX is offline   Reply With Quote
Old 04-26-2009, 08:14 AM   #4
Still Bill's Avatar
I started out with RTR some years ago; but, "graduated" from it to kits within 3 months.
If you are already in r/c racing and have some experience, I would suggest buying a new kit. So, you can build and tailor it to YOUR needs. Building is half the fun for many of us.
Another option is to buy a complete used car locally.
Great that you are keeping it fun!
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 04-26-2009, 07:09 PM   #5
Bill
Ok...just for some parkinglot fun...what would be the most economical method for a BL situation?? Should I get some kind of "roller" and but the motor from there? Or should I buy the RTR HPI??
Old 04-26-2009, 07:24 PM   #6
I had the hpi sprint 2 rtr not the brushless but put in a mamba 5700 brushless in,the car with a lipo was a great parking lot basher,only thing was it'll chew rear belts to shreads caused by pebbles getting caught in between the belts and rear cover and inside of rear bulkhead,i fixed that issue dremmeling out the rear gear cover or what ever was super close to the rear belts so that any pebbles would pass thru instead of getting wedged in between belt and rear parts.I also had issues with grease coming out of the front pully gear tranny and would build up in between the teeth on the pully and cause a lot of vibration so every now and then i would just take a small flat head and scrape it out,also the front end had a ton of play in the tires like you needed to tighten the axel nuts down and it also had way to much steering slop.
airwoods is offline   Reply With Quote
Old 04-26-2009, 09:41 PM   #7
Thirtybird's Avatar
if you find a decent used car for sale, you can pick up a new novak havoc system in most motor combinations (10.5, 13.5, 17.5 21.5) for about $150.
Racing a Kawada SV-10 in 2010
http://omgitsakawada.blogspot.com/
The VTA Photon! (Inactive - back to the Kawada!)
http://vtaphoton.blogspot.com/
Thirtybird is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
Any offroader in Penang Island. tkhoo Malaysian R/C Racers 3675 09-16-2009 10:13 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
Oceanside Racing SD Cgracing Racing Forum 579 04-24-2008 06:15 PM
Racing pictures! jnorth85 Nitro On-Road 82 01-12-2007 05:15 AM
Help!! AE or Losi Electric Truck?? fhm101 Electric Off-Road 28 10-12-2006 07:53 PM
LOSI 1/8 NITRO BUGGY TALK... STARSCREAM Electric Off-Road 192 04-12-2006 05:18 PM
