Old 04-25-2009, 07:57 PM   #1
Send a message via Yahoo to jrick78
Default chasing traction on a concrete????
Hey Race fans
We have a new on road track here in town. Im been out testing and cant seem to get traction to take high speed turns. Ive been racing on dirt for the last 5 years. So im not a board runner as a norm . The car pushs alot going in. Will a one way or spool help?
Ive tried the following
foam tires, not sure of the compound. rubber tires, they are the 24r.
Ive changed ride height a few times.
tried stiff front and stiff rear alot of different setting.
Ive ordered a set up board and different compunt tires. Ive also ordered a tc5.
Im running a tc4 with the penguin chassis.
jrick78 is offline   Reply With Quote
Old 04-26-2009, 11:26 AM   #2
Trips's Avatar
Trader Rating: 16 (100%+)
Forget foam tires for concrete. Rubber tires work better, softer compounds than you'd use on asphalt will help.
Go softer on the suspension rather than harder. a little more ride height than usual can be helpful too.
MARSHAL!!
Trips is offline   Reply With Quote
Old 04-26-2009, 11:48 AM   #3
jonest's Avatar
What rubber tires work on concrete? 24?
I know tamiya's M Grip does the job but it's a 26mm (width)....
jonest is offline   Reply With Quote
Old 04-26-2009, 11:52 AM   #4
mac853's Avatar
Exclamation
Just my opinion, how about to try RP tyres with non-RP thick insert and maybe(if you can find), old version JACO preglued rubberz?
mac853 is offline   Reply With Quote
Old 04-26-2009, 12:06 PM   #5
Trips's Avatar
26mm rims are still available, I'd give those Tamiyas a shot. I liked Sorex 20 and 24 with soft inserts on concrete too.
MARSHAL!!
Old 04-26-2009, 03:07 PM   #6
tallyrc's Avatar
blow off the track like your expecting to eat off of it...
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 04-26-2009, 03:25 PM   #7
Thanks for the info.
Im going to try a sway bar also.
Old 04-26-2009, 04:32 PM   #8
Trips's Avatar
Sway bars would be counter-productive in this case. They don't improve grip, they take grip away. THe reason I suggested a higher than usual ride height was to make the car lean more in the corner, which transfers more weight and increases grip... the sway bars are more for high-grip surfaces.
MARSHAL!!
Old 04-26-2009, 04:41 PM   #9
That makes sence.
Old 04-26-2009, 04:55 PM   #10
Trips's Avatar
By the way, here's a link to a great website with LOTS of info on rc car handling...
Elvo's RC car handling website
MARSHAL!!
Old 04-26-2009, 06:45 PM   #11
bvoltz's Avatar
Trader Rating: 44 (100%+)
Inside or outside?
Have you tried spraying the track? VHT, soda mix...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 04-26-2009, 08:40 PM   #12
We tried sugar water.
Thanks for the website
Old 04-26-2009, 08:48 PM   #13
Miller1's Avatar
Trader Rating: 36 (100%+)
rp30's seem to work great on concrete..wipe them with wd40
Miller1 is online now   Reply With Quote
Old 04-27-2009, 01:28 AM   #14
mac853's Avatar
Don't try swaybar on low traction and bumpy asphalt and on any concrete.
Then try using softer springs and lighter shock oil.
Why using WD40, if just cleaning why not tyre cleaner like YOKOMO or motor cleaner?
Old 04-27-2009, 01:47 AM   #15
Chris Adams's Avatar
I used to run on concrete. It was outdoors and was not the smooth type. Traction always sucked... just didn't suck as much with new tires. RP 30's were tire of choice. I would venture to say that Jaco blues would be pretty solid alternative. I never tried it but im not so sure I would use wd 40... Buggy grip em and you will be fine. Make sure you run a higher ride height if it has the seams with the black crap in between. They rarely create a smooth transition from slab to slab.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
