chasing traction on a concrete????
#16
jrick78
i under stand your drama with concrete, we had the same problem. We ended up putting a product called Boral surface coat over the entire track.
Is the surface dusty or glazed.
If the surface is dusty wash it down and apply a product called Bond Crete at a rate of 10 to 1 (10 gal of water to 1 gal of bond crete) apply at least twice, this should help.
Steven.
Steven.
#17
Paint the concrete with water proofing coats or boral surface coats.
#19
I used to run on concrete. It was outdoors and was not the smooth type. Traction always sucked... just didn't suck as much with new tires. RP 30's were tire of choice. I would venture to say that Jaco blues would be pretty solid alternative. I never tried it but im not so sure I would use wd 40... Buggy grip em and you will be fine. Make sure you run a higher ride height if it has the seams with the black crap in between. They rarely create a smooth transition from slab to slab.
