Old 04-27-2009, 08:33 PM   #16
Foxxrocket's Avatar
I've never drifted before, but there are some tips that can be applyied to racing in general. The first is, Slow is fast. Intentionally retard the speed of the car. Either by gearing it down, or using a 4 cell battery to cut down top speed. And then practice. Your lap times should improve from there.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 04-27-2009, 09:51 PM   #17
i drift a tt01 before.
at first i use all stock, but lock front and back, it drift good but can't keep in drifting mode all the time, it either over or under.
so i change the bearing, the run feel better but still can't keep in drift mode.
send i change the adjustable arm for front and rear and play abit of the camber and the toe, front toe out about 2 to 3 degree, camber for front -1 rear -0.5. than i drift nicely but still when come to flip 1 corner to other corner , it under steer.
3rd hop up, adjustable oil shock, set it to front soft and rear hard (for begginer, rear hard are more easyer to initial drift), never since i drift happyly.
hope this can help.
patricklui is offline   Reply With Quote
Old 04-28-2009, 05:30 AM   #18
Sweet tips you guys
grategenin is offline   Reply With Quote
Old 04-28-2009, 05:38 AM   #19
Ricky/C's Avatar
Send a message via MSN to Ricky/C
all the tips you'll need! >>> www.oneten.co.za
TRF 416 WE | LRP SPX Stock Spec| 17.5 SP | Sanwa M11
TRF 416 WE | LRP TC Sphere | Novak 3.5 | Sanwa M11
www.oneten.co.za >>>>>>>>>>>>>>>> Home of RC in SA
Ricky/C is offline   Reply With Quote
Old 04-28-2009, 08:21 AM   #20
freeway's Avatar
spool the front and rear diffs, soft springs and sway bars, toe in 3* in the rear, drift tires and manage your FDR. like the guy said above slow is fast.
freeway is offline   Reply With Quote
Old 04-28-2009, 09:48 AM   #21
Frank McKinney's Avatar
Some really good beginning drift techniques: http://www.hpieurope.com/tv13/?vidID=20
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 04-28-2009, 09:57 AM   #22
Dorigecko's Avatar
Send a message via MSN to Dorigecko
lock your rear, one way in the front.
as much power as your car will handle. hahaha... nah. something with good power and slower, torquey gearing.
Type T hpi drift tyres.
Works with damn near every car.
Suspension hardly matters. the best, easiest cars in the world can be stock springs with stock bloody air-friction dampers. alloy looks cool though.
Minimalist approach to start with. go up from there.
Dorigecko is offline   Reply With Quote
Old 04-28-2009, 10:19 AM   #23
these boys are really cool
http://rc-drift.com/rc-drift-forum/index.php
and dont use a 9 turn brushless set up for starters
i did
+ YouTube Video
sidecarphil1 is offline   Reply With Quote
Old 04-28-2009, 01:53 PM   #24
Spool in the front? You mean one-way?
Old 04-28-2009, 02:41 PM   #25
no they use spools front and rear
i liked a oneway in the front as a hand brake affect
but spools are common front rear , or tight ball diff front
Old 04-28-2009, 03:14 PM   #26
spngr311's Avatar
That is pretty much how I've setup every drift car I've had and they work great.
The only suspension thing I would do is put the softest springs I can get in the front and the next softest in the rear. The reason for this is that most of the drifting I have done have been on less than pristine surfaces and you need something to accommodate the bumps in the road since the tires are not going to help with that!
spngr311 is offline   Reply With Quote
Old 04-28-2009, 03:58 PM   #27
Spools are just like locking diffs right? I've tried locked front and rear. Didn't like it, too much understeer.
Old 04-28-2009, 04:18 PM   #28
The spool and one way is really personal preference, but spool indeed makes car understeer in slow speed condition.
Here I am running with regular VTA track day setup with F/R ball diffs and soft rubber tires... car runs wider, but on a slippery floor u can still get it to drift..
+ YouTube Video
dendog220 is offline   Reply With Quote
Old 04-28-2009, 06:36 PM   #29
freeway's Avatar
spool is when you take the ball bearings and replace it with bicycle tire patches or any material to replace the bearings. i started tightened ball diffs on a cyclone TC and when i got the xray spooled front and rear diffs, now standard one way for the front and spool rears. some find it hard to drift or keep drift on front one way but starters use spool then front tightened ball diffs after they get better. below is a diagram from another forum on how to spool ball diffs, its off an xray but any ball diff will have the same internals to be removed and covered with the tire patch.
Old 04-28-2009, 10:20 PM   #30
Dorigecko's Avatar
to remedy understeer with two locked diffs, increase steering angle (by means of cutting bits if you have to), add more power, and harden the rear more.
i do this with a bloody TL-01 and it's the best thing. ever.
beats the shit out of cyclones.
I SO hope someone bitches about that comment.
TC3 Forum Lowrider Electric On-Road 12196 10-13-2017 09:47 PM
MINI Z beebop Indonesia Racing 7572 01-24-2017 10:16 AM
RC Drifting Section briangomez931 Manila Racers 10549 05-30-2015 03:36 AM
Tips for installing HPI T-drift tires Cheezburger Electric On-Road 18 06-08-2009 07:58 PM
ANY Tamiya TT-01 Drivers in Jurong Area? Sleepy29 Singapore R/C Racers 35 01-22-2009 08:03 AM
Drifting Tires: Buy or Make? kang45 Rookie Zone 11 12-04-2007 05:37 AM
