Old 04-25-2009, 05:09 PM   #1
Lightbulb Quality/Quiet 64pitch Spurs? who makes them
what are your personal opinions on who makes the BEST 64p Spur gears? I mean a quality quiet warp free spur gear.
thanks
intron is offline   Reply With Quote
Old 04-25-2009, 05:13 PM   #2
Kropy's Avatar
Send a message via AIM to Kropy
PRS or BMI, Both are excellent choices
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 04-25-2009, 05:50 PM   #3
Regional Moderator
CarbonJoe's Avatar
For spurs, PRS or RW.
BMI makes pinions, not spurs.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 04-25-2009, 06:28 PM   #4
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 04-25-2009, 06:31 PM   #5
wingracer's Avatar
Trader Rating: 24 (100%+)
PRS are fantastic.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 04-25-2009, 08:14 PM   #6
trailranger's Avatar
I use PRS pinions and spurs. I also use Kimbrough spurs for the larger than 88T spurs. No issues with noise or power transfer. Spurs wear out after a few races so plan on replacing those after a few hours of use. If a pinion is worn out or has knicks it will make noise and wear out the spur quickly. Bad gear mess also leads to excess wear and noise.
"If everything seems under control, you're just not going fast enough." - Mario Andretti
trailranger is offline   Reply With Quote
Old 04-25-2009, 08:46 PM   #7
Tpg racer's Avatar
Just use 48 pitch spurs and pinions if ur not racing at the highest level... they really last a hell of a long time...
In fact, I use them for racing too...
Tpg racer is offline   Reply With Quote
Old 04-25-2009, 08:51 PM   #8
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
general Rule of thumb, As long as the pinion and spur Gears are from the Same MFG ou cant go wrong.
personaly i have always preferd Kimbrough or Yokomo( aka xenon)
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 04-26-2009, 04:07 AM   #9
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
I have tried just about every brand at one time or another, and used Kimbrough almost exclusively since racing gold-tub RC10's, but a few months ago I tried an XRay spur because it was the only brand available in my LHS in the size I needed...now I won't use anything else. It is the truest, roundest, most precise spur I have had experience with...I had to re-learn how to set proper gear mesh because they require so little backlash!
-rocky b
flatspunout is offline   Reply With Quote
Old 04-26-2009, 11:57 AM   #10
Trips's Avatar
Trader Rating: 16 (100%+)
What do you use to clean the mess off?
MARSHAL!!
Trips is offline   Reply With Quote
Old 04-26-2009, 12:31 PM   #11
niznai's Avatar
thanks
Kawada for both. I have used others but prefer these for quality.
I think you better check what bolt pattern you have/need. Some use six bolts some use eight (four). Kawada does eight.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
